50% power with 100% throttle ?
  • numse1964
    • Oct 2010
    • 37
    Hi
    I have a problem with a turnigy 60 A boat esc and my Hitec agressor CRX pistol radio.
    This is my first boat build from scratch.
    Turnigy 60 A esc
    Leopard 28/58 motor
    3 lipo cells
    When I got to the lake and started to the drive the boat it looked nice, but slow...
    Everything was room temp after the cruise.
    When I got home, I connected the motor to a RPM/KV reader and there was only half the rpm/kv the motor was appel to.
    I then tryed another turnigy 60 A boat esc with the same result. Only half the power with full throttle.
    My radio setup for the throttle is:
    100% forward - 100% backward
    No ABS
    Subtrim throttle 0
    End point adjustment throttle 100% forward - 100% backward
    Exponential throttle 0%
    ESC setup:
    Only forward
    3 lipo cells
    3,2 V Low voltage cutof
    7,50 degrees Timing
    I tryed to reset both the esc and the radio with the same results.
    I have changed the motor with the same result.
    I have done the throttle range calibration on the system twice. Same result.
    The radio is working fine with a ARTR boat on another model memory and 2 diffrent cars.
    I am running out of idears , so if anybody have an idear what the problem maybe is, I will be very thankfull
    Best regards Henrik
  • Steven Vaccaro
    • 8721
    I had a similar but diff problem. After the initial take off, the esc would drop to 1/2 throttle. On advise from the guys on here I switched to manual programing for the # of cells and lowered the voltage cutoff and it worked.
