Painting ISSUES!!
  • monojeff
    Moderator
    • Nov 2010
    • 2562
    Painting ISSUES!!
    Well this is the last time I use Krylon spray paint!
    I have had the same issue happen to me twice now once with red paint and this time with yellow paint.
    I primed a hull that I sprayed a dust coat on then a first coat.
    Waited 24hrs and then applied a second coat which decided to alligator in a few spots.
    Not sure why this keeps happening??
    I have never had any issues before but from now on I am using dupli color which I have never had any issues with.
    Any ideas what could be causing this??
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
  • JimClark
    • 5907
    Humidity?
    Billy Graham
    • 6sHyper
      <<<Surfs up!
      • Jan 2011
      • 597
      If its alligatoring then its because the substrate you are spraying on to has surpassed its window of recoatability.
      Lehmans terms: You waited too long before applying the next coat/stage, you need to sand/scuff it before applying more.
      **Sometimes spraying a coat too wet can cause this too.
      • monojeff
        Moderator
        • Nov 2010
        • 2562
        Originally posted by JimClark
        Humidity?
        I painted it yesterday and the humidity today I think is about the same but I could be wrong.
        Before when I was painting my boat with the red paint I sanded it first and then painted and still had the same issue.
        I didn't put it on to wet so don't think that is the issue.
        It's crazy I have never had issues like this before but recently with these 2 hulls.
        It is causing a lot of xtra work and is a PITA!!
        Now I have to wait till tomorrow 2 try to sand out the spots and try to re-coat it and hope it doesn't do it again!!
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • ray schrauwen
          • 9472
          If you try Molotow Premium this will not happen. Paints onto anything, even when wet, doesn't run unless you are a complete idiot and leaves no dust finish. This stuff is wacky!
          http://artprimo.com/catalog/art_prim...mium_info_page
          • siberianhusky
            • Dec 2009
            • 2187
            A friend did a few of his SV's this winter, can't say humidity was his problem, did it in the middle of a Canadian winter, followed the directions exactly, re-coated within the allowed window, some colours went alligator some didn't. There was no rhyme or reason, was all Krylon Fusion from start to finish.
            I have used dupli-color with 2 part urethane clear, and base coat/clear coat, personally I have no reason to change, these systems have worked flawlessly for me for many years.
            The last paint issue I had was with that airbrush paint, I don't think I heated it enough to cross link.
            • dana
              Banned
              • Mar 2010
              • 3573
              is it contained to one area? or the whole hull is doing it?
              • monojeff
                Moderator
                • Nov 2010
                • 2562
                Two spots did it not the entire piece I was painting.
                They were decent sized areas that did it.
                OSE GIFTING ELF
                HAPPY HOLIDAYS!!
                • dana
                  Banned
                  • Mar 2010
                  • 3573
                  Can I ask where on the hull? Does it get covered up? Krylon can be a real pita. It seems like the less prep work I've done with that stuff the better the results lol
                  • LarrysDrifter
                    Big Booty Daddy
                    • May 2010
                    • 3278
                    I recently painted a cat using Dulpicolor acrylic laquer(can't spell) auto match paint in 8oz cans. It turned out nice for rattle can paint. Here's a link:
                    http://forums.offshoreelectrics.com/...ad.php?t=25263
                    • LarrysDrifter
                      Big Booty Daddy
                      • May 2010
                      • 3278
                      Husky, the Fusion paint is for plastics.
                      • siberianhusky
                        • Dec 2009
                        • 2187
                        I don't know, it wasn't my boat, not my paint job either, he used exactly what was recommended to him for the SV.
                        Like I said I like base/clear or laquer/clear.
                        • tiqueman
                          • Jul 2009
                          • 5669
                          I always always always have this issue w/ Krylon. Its humidity. Not your prep, not your technique. I sent an email to Krylon about a year ago when I had all kinds of issues. I can dig up the email if youd like, I think I still have it. I do recall her name being Julie. She even stated its a humidity issue and refunded me all my money I had spent on trying to get the project corrected. Krylon sucks and I will never try using it again.
                          • ray schrauwen
                            • 9472
                            Moisture, no problem!!
                            Lets see you do that with Krylon Homie!!
                            • tiqueman
                              • Jul 2009
                              • 5669
                              cool stuff
