32" FighterCat (Apparation)
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    SOLD I bought this cat from FighterCat57 a while back and was going to do some testing,then some things came up,so I have no use for it now. I started a build thread on it,but didnt get too far. There are a few pics there too.
    The hull is 32" long and has fresh paint as of 5-15-11. The decals are NOT cleared over,so if you dont want them you can take them off. It has been re-inforced with fiberglass matting and I added flotation in the bow. It also comes with a thru-hull water fitting as well as a water outlet, water cooled motor mount, stuffing tube for .150 flex and has teflon in it, a used .150 flex with drive dog. I converted the strut to 3/16 so a common stub shaft can be used. A servo mount is included as well as a length of silicon water tubing to be cut at your desired length. The hull was properly sanded with 220 grit paper and painted with Acrylic Laquer paint and cleared. The bottom of the hull has cracks in the gel coat only. They do not go through the fiberglass. It came to me with the motor mount mounted and with a metric stuffing tube. The mount was too far forward and the hatch would not close fully, so I moved it to the rear and installed a SAE sized stuffing tube. I of course filled the old stuffing tube hole with epoxy. The hull is very solid and would make a great hull if you have a motor/esc to drop in.
    Also comes with antennae mount. Stand is NOT included.
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    More pics. Feel free to ask any questions.
    • tunnelvision
      • May 2010
      • 685
      I'll take it Larry. Send me your paypal. Thanks.
      Go Fast...Turn Right...
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        Sold, pending payment.
        • tunnelvision
          • May 2010
          • 685
          Payment sent! Thanks!!
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            Sold!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
