PAINT: Spray guns, tips, links to supplies...
Would I need anything special for a compressor to run a HVLP gun? I guess it would need a big reservoir tank.
That is a good looking gun but is there anything similar by a worldwide company, the Sharpe only seems to be available in the states and once I factor in shipping, tax and postal costs this end it looks like about $240 to my door, if I can get something similar from a bigger brand locally it would work out less than half price. In that sort of price range I could get a Fiac Merlin or UPOL maximum mini, anyone used either of these?
edit: ouch I just found that HVLP guns run on turbines not compressors, the cheapest used turbine on ebay is $400 as opposed to $160 for a compressor, and I'm guessing you cant run air tools or pump your tires up with a turbine so it lacks the versatility and cost sharing of a compressor. Is HVLP definitely the way to go? It would take me a very long time if ever to break even with rattle cans at that price.
http://www.harborfreight.com/hvlp-de...gun-46719.htmlIMPBA 20481S D-12Comment
Here is a link to help you set up a paint gun. The first link is part one and the second link is part two.
Bring powerful images to life in seconds, AirBrush has all the tools you need to create everything you can imagine.
This is the one I use. I spray primer and color coat. It can be adjusted for small touch up. Watch the video.
http://www.harborfreight.com/high-vo...gun-66222.htmlComment
http://www.harborfreight.com/high-vo...gun-66222.html.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Brushless, the size of the compressor you need is all dependant on how big of a job you plan on spraying? If for example your just spraying a 32" boat a little "pancake" style compressor would get the job done for you, basically any compressor would as long as you had like a 20 gallon reservoir that would be enough air to get a coat on then it could recover while your waiting between coats. To do a complete car the bare minimum would be a 60 gallon reservoir and pump capable of bare minimum 10.3 cfm@90psi.Comment
these are a great buy, comes with 3 tips, so its good for primer and base and clear. All metal construction, so as long as you clean it properly it will last forever. (cheaper harbour freight guns have teflon oand plastic internal seals that wear out)
keep an eye out for used or no reserve $0.99 starts too, deals are there
These are really cheap, but i would probably buy the first link i posted with 3 tips:
this gun is worth $500+ heck i'm going to bid on it!
this is an awesome gun!:
And theres tons more...........Comment
Everyone should have an air compressor around their home. Buy the highest SCFM rated, 110 volt air compressor you can afford. When I sprayed my Whiplash I used a small Craftsman 1.5 horse 2 gallon compressor (it was barely enough and ran constant).Last edited by detox; 05-21-2011, 07:20 PM.Comment
I have a small oil lubed Craftsman that my wife got at a garage sale (needed a gasket) and I added a 5 gallon tank from another garage sale compressor. Total investment is under $25.00. This is more than adequate to supply my detail gun.IMPBA 20481S D-12Comment
I ended up buying spray cans online http://automotivetouchup.com/spray_paint.asp
I got their basecoat clearcoat system. I got a couple of runs in the clear (happened really fast) but I am pleased with the results.Attached FilesComment
