did u try moving the turn fins about 45 degrees out instead of the stright down? that may help ya in the turns some so it doesent jump out of the water
pursuit mono build
About the turning issue. The center tabs seem low. Have you tried lifting them way up to see if the problem is still there?Steven Vaccaro
its just the angle of the pics the tabs are 3mm from the bottom they are trimmed down though, i have had they raised up and does it. now i was just thinking if i have them to high (3mm above and not flat with the bottom or just a hair higher than the bottom) when i dial them down water is going to contact the last bit of trim tab lifting the rear rather than the trim tab being more of extension of the boat if they were closer to the bottom , does that make sense. steve can you tell me how far yours are mounted from the bottomComment
