mhz trimax crap to the max
  • westbeach
    OSE Rocks!
    • 951
    Damn interesting indeed Rip. What is a Stevens Pipe in the description? Sounds like the knurled sleeve. I wonder if it needs to be glued into place into the transom??
    Originally posted by RIPFENCE
    ok i do not take my words back yet///look at what i found westbeach...mhz does make the deucemax its called the trimax eco
    http://www.mhz-powerboats.com/mhzpow...0e410dad714b7c
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • RIPFENCE
      • Sep 2009
      • 1332
      you probably need to smoke a stevens pipe to get on the correct plane of thinking to figure out the deucemax
      "FE" STANDS FOR FRUSTRATING EXPLOSIONS
      • westbeach
        OSE Rocks!
        • 951
        Ahh...the secrets of our European counterparts have been discovered. Must be much larger than the average bong!
        http://forums.offshoreelectrics.com/...4&d=1272355600
        I did find this picture, looks like the knurled sleeve is glued into the transom.
        • H2OCamel
          FAST ELECTRIC EVERYTHING
          • Oct 2007
          • 484
          wow I have been looking at the trimax mini and middle for two different project but can't find anyone who has installed one.
          "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
          • RIPFENCE
            • Sep 2009
            • 1332
            well after much testing i have got the ducemax dialed in and here is all thats left......
            a speedmater!!!!! the trimax eco went straight to the trash
            • b.mcdaniel.2009
              • Sep 2010
              • 1641
              Dang Aaron. Sucks you got burt on that. That Speed Master strut looks better anyway
              ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
              • fatboyelectric
                • Feb 2011
                • 84
                How about a vid on this boat with the SM stinger......
                • RIPFENCE
                  • Sep 2009
                  • 1332
                  #23
                  Yes i want to get this one up and going...now i wait for a 3/16 flex to get to me and i am good to go..i am curios to see how the racemaster will go...hey brad i got a really good deal on the boat so its no biggie...i was just curios about this trimax and i wanted it to work but i am not even sure if i had all the correct pieces...lol...i gotta get my wife to film...but she likeS to cook so its a tough tradeoff..do not want to ruin the good eats
                  • b.mcdaniel.2009
                    • Sep 2010
                    • 1641
                    #24
                    No no no never bite the hand that feed's you lol....Kinda off subject but how do you like you cyberstorm. Pm me if you want to keep the thread clean
                    • makaveliks
                      • Jan 2009
                      • 31
                      #25
                      I would think you would want the 2 shafts mounted in a "V" shape off the drive looking from the back, not straight side to side... Then they hold it in an up down position and side to side and i would that would keep it from twisting.
                      *edit* did you really throw it out? If not, you can sned it my way and I'll build a boat to try it on... LOL ALSO I would think the set screw may be to grease the shaft without pulling it out. On the MHZ website it looks like it is a fitting for a line, which I would think would be for an oiler...
                      • H2OCamel
                        • Oct 2007
                        • 484
                        #26
                        You are correct. that is the reason for the twisting.
                        • lipdaddy
                          • Feb 2010
                          • 48
                          #27
                          hahaa..so much for the trimax..i definately do not have that now do i??? ok i take back what i said about the trimax...mine is the deucemax...like going to drop a deuce max
                          Thanks, I haven't laugh this hard in a while.
                          nice move with the speedmaster.
                          Ryan
                          • CornelP
                            • May 2009
                            • 745
                            #28
                            That is (was) a Trimax Eco, the simple one of the lot, with only two anchor points. Those two should have been mounted a LOT higher on the transom. Anyway, this version was meant for boats in the 600-800mm range, so it was a bit small for the racemaster...
                            • RIPFENCE
                              • Sep 2009
                              • 1332
                              #29
                              Very good observation guys...i may have figured this out if i had taken the time to really think about the situation. But yes it did go to the trash unfortunately...thanks for the insight and for future reference others may know a little more on how to mount it correctly...makes sense to angle the turnbuckles higher
                              • Alfa Spirit
                                • 2131
                                #30
                                Trimax drive can work fine if it' s well installed.. LoL But it' s very expensive. Same as Ripfence, I will use a Speedmaster from OSE in my MHZ Racemaster, flex is from Prestwich Model Boats in England.
