mhz trimax crap to the max
  • RIPFENCE
    • Sep 2009
    • 1332
    ok so what is the actual point of the mhz trimax drive? has anyone used this drive with any handling success? i bought an mhz racemaster that is equipped with the trimax..the handling is atrocious at this point in time...the drive moves all over the place and is causing nightmare turning and the straights are no better..i will get a few pics together and show how its mounted..there is really nothing from keeping the drive from swivelling left and right..i guess i am a little frustrated by this because its such a gorgeous boat with no handling or speed to show for the good looks...i am wondering if the trimax is just an over engineered,expensive turd...speedmaster never lets me down like this!! any input is appreciated and maybe some of you have set one up properly
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  • westbeach
    OSE Rocks!
    • 951
    Sorry to hear about your problems. I am sure one of our friends from across the pond will chime in. The three rods should not move once they are locked into position. Which I am sure you have gone over it with a fine tooth comb. Or unless it was install wrong?? Pics might tell more.
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • RIPFENCE
      • Sep 2009
      • 1332
      here are some pics to show the swivel thats happening...there is set screw in the middle but when tightened it hits the flex cable and then the cable will not turn..the ball links will continue to swivel even if the linkages are snugged up tight
      • RIPFENCE
        • Sep 2009
        • 1332
        maybe across the pond they have some good success..and will make me a trimax believer...
        • westbeach
          OSE Rocks!
          • 951
          I think you might have a ripped off version of the TRI-MAX, look at this link http://www.mhzusa.com/Trimax-Middle-m-1727-M.htm
          There reason why it is called a TRI is because it has 3 arms coming down to the drive shaft, and there should be 2 plates that keep the shaft sealed and not able to move around. I have never heard anything bad about the tri-max except of cost.
          • RIPFENCE
            • Sep 2009
            • 1332
            hahaa..so much for the trimax..i definately do not have that now do i??? ok i take back what i said about the trimax...mine is the deucemax...like going to drop a deuce max
            • westbeach
              OSE Rocks!
              • 951
              You might as well throw out that drive as the two arms won't stop the shaft from turning from the torque of the motor/flexshaft. I would ask for some refund on that so called tri-max. It is missing lots of parts. Not worth the money.
              • westbeach
                OSE Rocks!
                • 951
                glad to hear that you taking it cool!
                • RIPFENCE
                  • Sep 2009
                  • 1332
                  i hear ya west..i may just put a trusty speedmaster in it and remove the monstrosity off the transom. thanks for some direction because everthing is not always what it seems..i wish i could change the title of the thread now!!! sorry to mhz trimax users
                  • westbeach
                    OSE Rocks!
                    • 951
                    No problems Rip; glad to share some light onto your problem. I had been eyeing the trimax before, but I had to take a double look at yours and the real trimax. It didn't look right.
                    • RIPFENCE
                      • Sep 2009
                      • 1332
                      ok i do not take my words back yet///look at what i found westbeach...mhz does make the deucemax its called the trimax eco
                      • Rumdog
                        • 6453
                        Looks like it isnt really intended for wet well style mounting. Is that knurled looking peice on your drive?
                        • RIPFENCE
                          • Sep 2009
                          • 1332
                          rum are you referring to the picture from the link i posted? the knurled silver piece is inside the boat and is glued in..not real sure about the function of that piece either..something is just not adding up here..i will really need to fool with this thing some more or just remove it completely to figure out its true function..it may be installed wrong
                          • Rumdog
                            • 6453
                            If you pop the caps off the ball links, can you rotate the entire strut? It may be threaded into the knurled peice.. and may be a little loose.
                            Just a guess really.
                            • RIPFENCE
                              • Sep 2009
                              • 1332
                              i have popped the caps off and you can slide the strut forward and backwards but there is no threads there..i was wondering about that too..iwas thinking about soldering on the drive where the strut is turning as a temporary fix to keep it straight and not swiveling but it may still be bad handling
