Cutting flex shaft to length
  • Southwest
    • Sep 2012
    • 274
    Soldering the cut end was suggested sometime ago for cables used with set screw couplers , so they don't give when set screws are tightened. Octura couplers if i'm correct don't use set screws. I like either type if quality is GOOD.
    • iamandrew
      • 577
      I use Permanant LocTite instead of soldering the ends of the cable.
      stops fraying and very easy to use :)
      • Southwest
        • Sep 2012
        • 274
        LocTite is used for the cable that inserts into cable shaft and heat is used to to release from cable shaft.
        • Basstronics
          • Jun 2008
          • 2345
          I wont use loctite for Flex Cables again. I got the high dollar Loctite stuff and its let loose on a few occasions. My wire drives hold up 100% no failure though...
          • iamandrew
            • 577
            One of my friends is running a 1.9M Maratimo Cat from MHZ with 2 5HP RCMKs and used Loctite on his Flex to stub and its still fine. that thing would have a lot more stress on it than well, almost anything else hahahah
            All depends what kind of Loctite you use, theres a lot of different types, some are for oily locations which are permanent.
