Fighter Cat Twin
  • Igoreski
    • Apr 2010
    • 77
    Fighter Cat Twin
    Just got it back from the paint shop.Took my friend a long time but the job is near perfect.Running Tacon 2550kv's with 120a Sea King ESCs.Using a 5a BEC and a Traxxas 2075 w/p servo.Total length is just over 40"
  • b.mcdaniel.2009
    • Sep 2010
    • 1641
    Where did you get the jacket's for the Tacon's?
    ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
    • millzee
      Ozzie Bloke
      • Nov 2010
      • 1092
      look's great, any video's on the way?
      "Gimmy Toyz for FUN"
      • Igoreski
        • Apr 2010
        • 77
        The water jackets are from this site OSE for the Fieago XLs and they were a tight fit so I oiled them first.The video will have to wait unless you can cut a trench in the ice for me,MN / WI lakes are still bad.Forgot to mention I am using wire drives and Octura X442s modded with 110mm Fighter cat stingers.This hull and hardware are a very nice combo with lots of room.
        • marko500
          • Aug 2008
          • 861
          Fantastic job! I really like the way the window on the hatch looks. Nice to see something different.
          Mark
          • properchopper
            rcgoatbuild@snotmail.com
            • 6968
            Gorgeous ! Love the split canopy treatment.
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              Nice build. No offense,but you should have re-inforced the hull. I have one,and its thin and flimsy. Good luck with it and Ill be watching for a video soon as your ice melts.
              • Igoreski
                • Apr 2010
                • 77
                I did, I filled the front with minimal expanding foam over 3 days and built a fiberglass bulkhead sealing the front off.Then I painted it white to seal from water.The motor mounts to the transom is connected in resin and the stinger bolt plate is 1/4" thick.It is all one unit on each side.The hull was more than twice as strong as my EKOS hull before I started and now it's very rigid.The rudder plate in the transom is also 1/4" fiberglass with 4mm threads cut into the glass like the 3mm ones on the stingers.I never weighed my EKOS but this one is 6.1lbs complete W/O the big battery packs,800mah for the BEC is in the weight.
                • JPriami
                  N4FOX
                  • 1675
                  Looks good. Nice canopy layout
                  • LarrysDrifter
                    Big Booty Daddy
                    • May 2010
                    • 3278
                    Good to hear it. I hate to see or hear about any hull cracked up or broke open because it was ran "as is". Great job on the build.
                    • ray schrauwen
                      • 9475
                      Beautiful job! Can't wait to see how those Tacon motors do.
                      I made a pair of coolers for a pair of 5050kv Tacons like yours, pretty easy for me & my lathe.
                      Nortavlag Bulc
                      • Igoreski
                        • Apr 2010
                        • 77
                        That thing is going to sound great with the 5050kv motors,they will hear you coming from the other side of the lake.Are you going to use 2s or 3s ?
