Burnt out JST Connector
  • bettaman
    • Feb 2011
    • 58
    I have a Turnigy 4000mah 3s lipo and have burnt out the JST balancer connector.
    How are these replace.
    would this be the right product? https://www.hobbyking.com/hobbyking/...idProduct=9730
  • FloatDaBoat
    Bare Bones Fabricator
    • Sep 2009
    • 368
    Those are the correct connectors. "Burnt Out" isn't descriptive enough to advise on how to replace it. Did you melt the JST plug trying to measure voltage? Or did the wires somehow become shorted together? A pic would help in determining what type repair's needed . . . .
    • sailr
      • Nov 2007
      • 6927
      Nope. That's polyquest. The wires are wired up wrong and too many spaces in the plug.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • bettaman
        • Feb 2011
        • 58
        Whilst I was programming an ESC my father was out soldering one of those HK Low Voltage buzzers. The solder must have gone across the connections so when plugged into the battery it sparked and melted/burnt the jst plug coming off the lipo.
        • FloatDaBoat
          • Sep 2009
          • 368
          The link description states JST-XH balance connectors. I took a second look at the pic, & those connectors don't look like the ones on my Turnigy Packs. Hobby King might have used the wrong product picture in their listing. This sort of thing makes me leary of exactly what I'll receive when I order from them.
          • FloatDaBoat
            • Sep 2009
            • 368
            If the pins aren't burnt too badly, & still attached to the wires, you may be able to break the melted plastic off of them. Then you'd just have to insert them into a new plug. The pins have a tab on them that locks into the connector. They are easily removable - - provided you get the correct connectors. If the burnt connector is totally wasted, you might have to splice in a new one by soldering the new wires to the old. Good Luck !!!
            Be very careful, or you'll end-up shorting out the new one, also !!!
            • sailr
              • Nov 2007
              • 6927
              I hate to be defeatist, but if I were you I would scrap that pack and buy another as cheap as they are. I certainly wouldn't risk going into the pack and trying to solder new wires in. They require a special aluminum solder to begin with and unless you already have that, the aluminum solder kits are several $$$ just by themselves. Just my 2cents worth.
              Mini Cat Racing USA
              • sailr
                • Nov 2007
                • 6927
                Just had a different thought. Post a pic of the connector that got trashed. I may have one to match it, WITH wires on it that you could hopefully just splice to the existing wires from the pack if they weren't compromised in the accident. I'd be happy to send you the connector/wires for free!
                Mini Cat Racing USA
                • bettaman
                  • Feb 2011
                  • 58
                  Thanks mate.
                  Its fine, I got to order a whole heap more stuff from hobby king and if i can find one on their website ill splice it in.
                  • Hpr115uk
                    • Sep 2010
                    • 15
                    Sailr !
                    Offering something you don't use to someone else for free is what this is all about !
                    Hats off to you sir !
                    • bettaman
                      • Feb 2011
                      • 58
                      agree, im in australia and it would be to much effort when im going to order more parts soon. greatful for the offer.
                      • sailr
                        • Nov 2007
                        • 6927
                        Thanks guys. Hope you find what you're after. The postage to send a freebie to australia would probably be a bit silly! Ha!
                        Mini Cat Racing USA
                        • Hpr115uk
                          • Sep 2010
                          • 15
                          What no free postage ? And I have to cover any import duty myself ? The deals off . . .
                          Kind offer though , any one got an hpr233 hull going free ?
                          Please .
                          • sailr
                            • Nov 2007
                            • 6927
                            Mini Cat Racing USA
