How I added caps 3 more to my T-180
  • FRED
    • Jul 2007
    • 233
    Nothing.
    • millzee
      Ozzie Bloke
      • Nov 2010
      • 1092
      Here's my spin on it, it's the same as properchoppers, I thought this was the easiest way.
      "Gimmy Toyz for FUN"
      • Cutch
        • Jan 2011
        • 31
        Thanks for the info.
        • JackBlack26
          • May 2007
          • 905
          Millzee, that looks awesome! Great job.
          • scoota
            FE DOWN UNDER
            • Dec 2008
            • 409
            Originally posted by ManuelW
            Hello Guys,
            -more smaller caps will work better than one big one, eg. 4x 220µF can be better than 1x 1000µF cap
            -keep the wire lenght between caps and ESC's as short as possible
            -try to use low ESR caps, like Rubycon ZL or even better Rubycon ZLH
            @ Scoota: Very nice, did the same on my 180's. Did you also have some troubles with the original solder on the circuit board? It took me some effort to solder them nicely together.
            Best regards,
            Manuel
            no just cleaned up the solder on the original caps with a small file & they soldered on with no problems, i do have a pretty good iron , it has a very fine tip & a boost button which doubles the wattage and gets the tip nice & hot
            Fred , the extra caps are soldered the same way as the original caps negitive to negitive & positive To pos , the caps wouldnt last 2 seconds if the were soldered the wrong way .
            Cheers jason
            UL1- 1515 castle/neu / 240 swordfish
            SV27- with UL1 running gear
            33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
            • speed restricted
              Brisbane boat floater
              • 12
              there go my plans for one large capacitor in a watercooled jacket. thanks for the info all
