Falcon 41 on 10s?
  • Alexgar
    • Aug 2009
    • 3534
    There is a swordfish 240 in the swap shop for 200$ fyi
      • 9488
      Originally posted by Alexgar
      I'd do a hydra ice hv so you had data logging if your buying new
      we are going to do testing once we start building more boats, so an Eagle Tree is a tool we should get
      but a Hydra would be a sweet direction
      • Alexgar
        • Aug 2009
        • 3534
        check this out
          • 9488
          That would be awesome!
          is 180amp enough?
          • Alexgar
            • Aug 2009
            • 3534
            not to famialiar with hv the highest i use is 6s what does the motor spec say?
            • Alexgar
              • Aug 2009
              • 3534
              im reading 110 amps that sound do able
              5692 that is
              Features:
              - High efficiency up to 95%
              - Powerful 4-pole design
              - High overload ability
              Specifications:
              Model: LBP5692/3Y
              Max Amps: 110A
              Lipo Cell: 5-13s
              Max Power: 5500W
              KV(RPM/Volt): 730KV
              Resistance: 0.0130
              No-load Current(15V) : 1.7A
              Diameter×Length (mm): Φ55.8×92
              Mounting hole depth: 8mm
              Length of extend Shaft : 20mm
              Shaft Diameter (mm): Φ6.0
              Weight: 880g
              • Alexgar
                • Aug 2009
                • 3534
                Specifications:
                Model: LBP5682/3Y
                Max Amps: 106A
                Lipo Cell: 5-11s
                Max Power: 4500W
                KV(RPM/Volt): 910KV
                Resistance: 0.0117
                No-load Current(15V) : 2.1A
                Diameter×Length (mm): Φ55.8×82
                Weight: 758g
                Model: LBP5682/3D
                Max Amps: 180A
                Lipo Cell: 4-6s
                Max Power: 4500W
                KV(RPM/Volt): 1670KV
                Resistance: 0.0040
                No-load Current(15V) : 5.5A
                Weight: 758g
                  • 9488
                  #23
                  5692 that is
                  Specifications:
                  Model: LBP5692/3Y
                  Max Amps: 110A
                  Lipo Cell: 5-13s
                  Max Power: 5500W
                  KV(RPM/Volt): 730KV
                  Resistance: 0.0130
                  Weight: 880g
                  That's the 730kv
                  I'm still leaning towards the 1000kv and that one shows more amp draw
                  • Alexgar
                    • Aug 2009
                    • 3534
                    #24
                    I found one over seas for 151
                      • 8012
                      #25
                      No offense intended, but would it not be wise to listen to folks who have actually raced 10S boats over 40" long? There are a lot of them on this board, and spending the $$$ based on the opinions of folks with no experience is...risky. It's you money though...
                      I would not be too concerned about the amp rating of the Leopards. That rating is based on watts, not amps - pick the motor based on watts, and 5500 is better than 4500. It is common to exceed the manufacturer's amperage rating in boats. For example the Neu 2215 is rated for just 65 amps continuous, but we normally run 130-150 continuous amps through them. As long as they do not overheat they are fine. Use a big enough prop and you can load any of these motors to 250+ amps if you want - the motors won't like it though.
                        • 9488
                        #26
                        what did you find bro?
                        we are still leaning towards the 5692 1000kv
                        this could be somewhat like Tyler's Conquest Open Cat
                          • 9488
                          #27
                          we could also runs twins, but I think single would be more simple
                          • Alexgar
                            • Aug 2009
                            • 3534
                            #28
                            i found the motor cheap but they want 50$ to ship ems only so its not that great of a deal
                            • Make-a-Wake
                              FE Rules!
                              • 5557
                              #29
                              For the 5692 on 10s you may consider an s240 or x457..............................
                              • Make-a-Wake
                                FE Rules!
                                • 5557
                                #30
                                Any progress................???
