Turnigy T-180 users please
  • Simon.O.
    • Oct 2007
    • 1521
    For all of those that have a T-180, can you please shoot me the following dimensions.
    I have attached a pic to show where I mean.
    Thickness of the unit over the fins between the cooling tubes.
    Width between the motor wires and the cap bank.
    Overall width, green line
    Thank you to anyone who may help me
  • millzee
    Ozzie Bloke
    • Nov 2010
    • 1092
    The height from the bottom to the top of the fin in the middle of the cooling lines is 28mm. The width between the caps and the wires is the same as the plastic bottom of the unit, 50mm. The overall width with over hang from the front of the wires to the very back edge of the caps is 76mm.
    "Gimmy Toyz for FUN"
    • scotthend21
      • Jan 2008
      • 23
      Hello Simon
      your green dim= 2.7 (68 mm ) board dim
      22.9 in ( 71.7mm) to capacitor end
      Red dim
      2.13in (55.2 mm)
      totalthickness 1.10 in ( 27.11mm)
      bottom to center of hoise barb0.84 in (25.00 mm)
      Hope this helps
      • Simon.O.
        • Oct 2007
        • 1521
        Thanks guys, now I have what I need
        • properchopper
          rcgoatbuild@snotmail.com
          • 6968
          Simon,
          I don't know if this helps, but when I had to stuff a T-180 into the confined spaces of my Tunnel radio box and have the wires and cooling lines line up in a convenient manner, I re-did the cooling fittings with some right-angle banjos from Kintec. I did have some problem unscrewing the old fittings on one T-180, and the last one I got, the stock fittings had some sealant around the tubes so I didn't try to unscrew them. Hope this might help !
