Eagle tree elogger v4
  • 6sHyper
    <<<Surfs up!
    • Jan 2011
    • 597
    #31
    Originally posted by JPriami
    that was some fast shipping!
    x2!!! holy crap! Steve's customer service is most definately top notch, my stuff gets here in a huryy everytime, fingers crossed my eagletree system shows up tomorrow or Friday.....................
    • millzee
      Ozzie Bloke
      • Nov 2010
      • 1092
      #32
      Great service, I gunno if I would have got it that fast if I had ordered it here in Oz. Seem's were all getting these things we'll have to keep this thread alive and help each other out with the set. hehe.
      "Gimmy Toyz for FUN"
      • oscarel
        • Dec 2009
        • 2127
        #33
        I just bought a $50 cert for $10 on ebay and I may get a elogger 150 for lower amp applications. I sold one last year to fund the usb recorder I have now and I wish I had kept it, oh well. But I think I'll be pleased with the upgraded specs.
        • dasboata
          • Dec 2010
          • 3152
          #34
          I recieved mine from Steve hooked it up last night I did a live run to make sure everything was hooked up right and I am very happy with mine I just need to get the gps and I will be happy you will love your !!! good luck Chris
          • DINO7
            • Jan 2009
            • 162
            #35
            recieved mine too...fastest shipping to Greece ever...ready to go in my mystic M..
            H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
            MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
            BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
            • millzee
              Ozzie Bloke
              • Nov 2010
              • 1092
              #36
              could someone be kind enough to post some pic's of the system wired into a boat so I can get a visual of how it should be set up. I would really appreciate it, I'm sure it's simple but it'd be nice to see one set up so I can make sure I get it correct. Thanks
              • Stuey
                • Feb 2011
                • 18
                #37
                Is anyone running these units over the amp rating on a regular basis, ? just wondering what effect it has on the unit? Does it take the amperage off the graph when you throw it all onto a chart on your computer? Or still record max amps even if you were to exceed 100/150 amps., depending on rating of your V4.
                • DINO7
                  • Jan 2009
                  • 162
                  #38
                  first test for mine had 186amp spikes....no problem with that .i have the 150amp version..
                  • millzee
                    Ozzie Bloke
                    • Nov 2010
                    • 1092
                    #39
                    do you have any pic's of the unit installed you'd be able to share?
                    • DINO7
                      • Jan 2009
                      • 162
                      #40
                      yes... but later.when going back to home
                      • oscarel
                        • Dec 2009
                        • 2127
                        #41
                        Should be easy, batt side of eagle tree hooks up to battery same colors, esc hooks up to esc, same colors. So the elogger is in series between battery and esc.
                        Did you get the power panel as well?
                        • millzee
                          Ozzie Bloke
                          • Nov 2010
                          • 1092
                          #42
                          Yeah, I got the panel, I would like a visual pic just to be sure what I'm doing is correct. I think I understand how it wires in I would just like to see some pic's so I can get some visual clarification on what I'm doing. I'm going to have to figure out where I can fit it too. It'd be nice if the each set of leads come out either end, that'd make my life easier.
                          • millzee
                            Ozzie Bloke
                            • Nov 2010
                            • 1092
                            #43
                            I played around and found that it was so simple that I was over thinking it and missed it. I added connectors and simply plugged my parallel adaptors into the wires marked battery and plugged the esc wires into the esc. I had the lcd screen, brushless sensor, gps and three temps sensors plugged into the unit, what a mess, wires everywhere. I'll have to find a way to tidy it all and keep it out of the way so for now I think I'll just get the boat in the water without the system for one quick run, then I'll add the system again and take the time to set it all up on the computer.
                            • JPriami
                              N4FOX
                              • 1675
                              #44
                              Make it nice and neat if you don't like messes.
                              I've got the elogger v4, LCD, GPS, brushless rpm, 2 temp sensors, throttle position and the rest of the boat crammed off in this little geico. Tried to keep it neat. Even a home brew grease catcher over the flex/collet area I made from a medicine bottle. Just clips in place.
