post rescue rigs here
  • dana
    Banned
    • Mar 2010
    • 3573
    as the title says.... im looking to build something simple and just trying to get some idea's... im thinking a brushed motor and nimh pack to run it....
  • lectriglide
    • 538
    Dana,
    take a look at the one Diesel6401 has. I think he uses a Proboat Apache now 'cause it maneuvers better with the steerable drives. He has vids in action on his sig links.
    http://forums.offshoreelectrics.com/...ad.php?t=16705
    • dana
      Banned
      • Mar 2010
      • 3573
      yeah it looks like it works ok, but i dont want to use a boat hull, i would rather make something even more simple. also one of the things i dont like about everybodys rigs is, they all seem to act more like plows than anything. im thinking pvc skeleton with carved styrofoam hull sorta shape. i would like to make something that glides thru the water but is still capable of a rescue. im thinking something along the lines of a rescue rig like diesel has, but making the sponsons shaped a bit more like rigger sponsons, so it moves thru the water nicely. jmo
      • pescador
        • May 2009
        • 499
        Check out the boogie board rescue boats on youtube
        Ducted fan
        Brushless
        They might give you some ideas
        This was my early attempt with a boogie board and packing tape it actually worked but I never used it.
        Namba District 16
        • G1ST
          • Dec 2010
          • 348
          Springer
          I built A Springer Tug. Great fun to build and run. I had most everything in my spare parts bin. I attach a PVC and pipe insulation fork for rescue duties
          • Skipster
            • Apr 2009
            • 106
            AQ Atlantic modified with Pitman 12v and 4 blade prop.
            twin 5000 mah NiMh in parallel it runs all day
            The front boom stays up until the boat gets
            to the rescue (boom in the water slows the boat down)
            A switch on the Xmitter "lowers the boom"
            and the stricken vessel is pushed to the dock.
            no matter where I run my boats
            everyone loves the tugboat most
            go figure - a 50 mph 22 inch rocket
            (Delta Force Vortex) and they wanna
            see the tug?
            You can lie to mother Nature
            but You can not fool father Physics
            The more I learn, the more I know I don't know
            • dana
              Banned
              • Mar 2010
              • 3573
              that looks pretty cool. maybe a little big, since i drive a civic but thanks for sharing! im interested in the yellow hydro in the pic, what is it? thanks
              • tim v
                brushless everything.....
                • 166
                had it going 47mph 6s with out the front piece on
                :canada
                • Skipster
                  • Apr 2009
                  • 106
                  Thanks Dana, she is a bit big but the
                  boom comes off easily.
                  It is being fitted with a fire monitor and a kort nozzle.
                  The Hydro is a Graupner Tornado
                  currently being fitted with a small outrunner motor.
                  for use on 3s.
                  Tim, 47 mph with the front boom fitted?
                  This I'd like to see.
                  Please shoot a video of it.
                  • tim v
                    • 166
                    with out it fitted on but we will see.....lol
                    :canada
                    • FE Wannabe
                      • Jul 2007
                      • 626
                      Dana,
                      Here is a video of my PVC rescue boat with boat lift in action.
                      In this video I was using a single brushed motor with a steerable Apache 24 outdrive. I was using a .130 flex cable from the motor to the outdrive and I kept having issues breaking it, so I went to dual ducted fans and a stick radio so I could control the fans independently.
                      I liked the idea of fans because I didn't want the rescue boat to get tangled up in fishing line or other floating obstructions.
                      If I was going to propel this with props again, I would probably use a separate motor and non-steerable drive attached to each sponson and use a stick radio to control them.
                      I use a separate channel on the radio to control the winch that raises and lowers the basket up to 17 inches below the water. The basket may seem unnecessary to some people, but I like the idea of getting an upside down boat out of the water as quickly as possible. Also, have you ever tried pushing a boat that is nose up? I have, and it does not work well; you will normally just make it take on more water.
                      This is fairly large, but it can easily be scaled to the size boats you need to rescue and can be pinned together for quick assembly and disassembly. I does fit easily in my 4 door sedan's back seat.
                      Brad
                      SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
                      • koshokid
                        • Jun 2009
                        • 14
                        If you're looking for a reliable rescue rig without making a huge specacle of things, you might consider using a mini boat with a ProBoat "baby duck gaff". Horizon Hobby sells the gaffs seperately and best of all, you can attach them to any boat you may already have. Click the link to check out my setup, it's so small I keep the entire rig in my boat tool bag. I've tested it out, it works like a champ with very little customization necessary.
                        http://forums.offshoreelectrics.com/...ad.php?t=22922
                        • JackBlack26
                          • May 2007
                          • 905
                          Here is my Apache rescue rig. It fits perfectly across the back seat on my 98 Civic 4 door. As you can see I notched the pvc fittings to fit the hull seams then I CA glued everything. Works like a charm and I would never run my boats without it! It's powered by a Mamba Max ESC in a balloon and the motor out of my Miss Geico. When at the lake, I plug in the ESC battery and tape the lid. It's stays on all day and only the radio gets turned on and off as needed. The boat and radio sit by the shore so anyone can use it when they need it. It puts in major work and doesn't break a sweat!
                          • Diesel6401
                            Memento Vivere
                            • 4204
                            Originally posted by FE Wannabe
                            Dana,
                            Brad
                            Do you have a build thread on this?
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • FE Wannabe
                              • Jul 2007
                              • 626
                              Thanks, I have been meaning to do one, but I have never got around to it.
                              This is the second of three revisions so far.
                              The first version was designed as a pusher only.
                              This second version I added the winch powered boat lift.
                              The third and current version I widened the area between the sponsons and added the Ducted fans.
                              It took some time to design but it works well and is always my best maintained RC craft. It is the first boat in the water and the last to leave.
                              It is funny, like someone else mentioned, it gets way more attention from the public than my 62mph H&M Drifter S!
                              Brad
