Watts Up Meter
  • GregS
    • 82
    Watts Up Meter
    I just want to get an idea of how useful people find this device. If I understand correctly you can only see maximum values after a run where as with an Eagle Tree Data Logger you get a graph of the whole run.
    Greg
  • Steven Vaccaro
    • 8723
    Thats correct. I use both. I like the simplicity of the Watts up when bench testing. The Eagle tree is far better when testing a boat on the water. We are waiting for the new Eagle tree micro thats coming out. I should have them in a week or two.
    • GregS
      • 82
      Thanks Steven.
      Greg
      • kck741
        • Aug 2007
        • 265
        Do you need a certain ESC and motor for this unit.
        S.S.R.C-Southern Style Radio Control
        • ED66677
          • 1300
          Nope! they have to be connected between batt and ESC, no matter what ESC!
          Emmanuel
          • ReddyWatts
            • 1711
            For sport running I still use a Watts Up meter at the lake when testing different props, mainly because of the cost and ease of use.
            0 - 100 amps limit.
            4 - 60 volts dc input limit.
            Measures mah used, amps peak, volts/minumum volts, watts peak, Watt hour.
            .001 resistance,
            It will add 1/10 of a volt drop to your controller input at 100 amps.
            +/- 1% accuracy
            All values update every 0.4 seconds. **Will not catch voltage spikes.**
            Has a connecter for reading your receiver battery volts down to 0V.
            Watts Up meter simulator
            ReddyWatts fleet photo
            • kevinlew211
              • Aug 2008
              • 586
              what happen if i go over 100amps limit? i will burn it up or its won't read? any device design for more than 100+ amp but cheap?
              • ReddyWatts
                • 1711
                Mine has read a peak up to 135 amps and it is still working. I dont recommend using it over 100 amps.
                • Punisher 67
                  Ignore list member #67
                  • May 2008
                  • 1480
                  I have taken mine to 135+ amps also , still works like the day I bought it
                  Necessity is the mother of invention.............
                  Youtube Video's http://www.youtube.com/user/Titanis2000
