flex shaft wont take solder
  • rchuntlsl
    • May 2010
    • 122
    I am helping a friend of mine, the shaft wont take any solder. I thought he was using the wrong solder, so I grabbed it last night and I took it with me. Well I lightly sanded it and cleaned it with brake cleaner. AND it won't take the solder. I am using the same solder I have used on on 3 of my shafts with no problems. Any ideas???
  • Alexgar
    • Aug 2009
    • 3534
    need acid flux to prep
    • Steven Vaccaro
      • 8720
      Some black flex cable requires a torch to solder them.
      • rchuntlsl
        • May 2010
        • 122
        I have a torch, propane, map, or gas welder.
        • rchuntlsl
          • May 2010
          • 122
          Is acid Flux readily available?
          • Jeff Wohlt
            • Jan 2008
            • 2716
            Did you sand it goood...down to clean metal and clean with acetone? Then use some flux. You may be getting it too hot and it won't take it.
            www.rcraceboat.com
            [email protected]
            • siberianhusky
              • Dec 2009
              • 2187
              I find STa-Brite silver bearing solder and flux to be excellent, haven't had as good luck with other fluxes even with the sta-brite solder. Usually comes in a package with solder and flux.
              • egneg
                • 4670
                IMPBA 20481S D-12
                • rchuntlsl
                  • May 2010
                  • 122
                  I cleaned it with brake-kleen. I'll try acetone.
                  I tried heating it with the soldering iron, got it hot enough to melt the solder. Then I tried the propane torch.
                  • rchuntlsl
                    • May 2010
                    • 122
                    Tried the acetone and sanded it again. The solder just beads up on this thing and drips off. I have never seen anything like it. The flux i tried seems to be useless. The high quality solder has a rosin core, but it is no match for this shaft. I think I will have to try some other flux. The other shafts I have done did not require me to flux them at all. The good solder with the rosin core did just fine.
                    • HOTWATER
                      • Nov 2008
                      • 2323
                      Sta-brite and a pencil torch is all I have ever used...works perfect!
                      "Will race for cookies!"
                      IMPBA D12
                      My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
                      • rchuntlsl
                        • May 2010
                        • 122
                        Well, I got it and here is how. I used some tinning flux, which did not help much. I took a 1/2 copper pipe cap, heated it up with my torch. Filled it completely up with solder to make a little bath. I hit the shaft with a wire wheel. Heated everything up fairly hot. Dipped the shaft in the pool of solder several times till it finally took. It is not great, but it will never unwind. I then cleaned it all up with the bench grinder and wire wheel, it looks good. Hope I never have that much trouble ever again.
                        • siberianhusky
                          • Dec 2009
                          • 2187
                          Rosin core solder is for electronics, probably 60/40 lead tin, very soft, at the least acid core would be better.
                          You really should be using silver solder, no name stuff is available at most hardware stores, the sta-brite flux is the key to good soldering.
                          • dana
                            Banned
                            • Mar 2010
                            • 3573
                            ive def had issues getting solder take when i got it too hot. after that its a real pain to get solder to take, even after cooling it down,re-sanding and cleaning. kinda weird
                            • LarrysDrifter
                              Big Booty Daddy
                              • May 2010
                              • 3278
                              Where do you buy the Sta Brite?
