Power Suggestions for 36" rigger
  • jpracing1997
    • Mar 2008
    • 535
    I am open to any suggestions, this rigger is 36x20 and can run 4 up to 6 cells. I have any combo of batts and a castle 180 hv and cheap 200 hobbyking esc's. Seaking on the way also. I am looking to get in the 70+ mph range with this rigger, and it's only for saw type racing, so run time will be short. Thanks in advance.
    • 9479
    What about a CC1717 on 6s with a big prop?
    • Jeepers
      • May 2007
      • 1973
      he has like 2 other threads with questions concerning this set up, Raptor,and Fluid have already gave suggestions on his current 4s setup to get this boat in the 70's, but he seems to want to put more cells and another motor to get the SAME 70 mph.
        • 9479
        • m4a1usr
          Fast Electric Addict
          • 2032
          Which rigger are you running?
          John
          Change is the one Constant
          • jpracing1997
            • Mar 2008
            • 535
            It was built by Paul Packmayer. I think they said it was a cajun bullet.
            • jpracing1997
              • Mar 2008
              • 535
              I tried all the props I had with me, and I guess I'm gonna have to get some more that Fluid and raptor suggested. Until then I'm pulling the motor out and going a different route. I have 2s,3s,and 4s packs so I can go different routes. Will a 1527 1d or 1y be a better motor for a 36 inch rigger? Just get me started with the proper motor for this boat and then I can go from there. Somebody said that a 1521 1.5d would have to swing a bigger prop and that would cause prop wash. So I want the best possible motor for a saw setup for this rigger. Thanks in advance
              • Jeepers
                • May 2007
                • 1973
                why don't you post a pic of the hull? so Brian and Jay could tell you if it really is a Cajun Bullet.
                • jpracing1997
                  • Mar 2008
                  • 535
                  ok, I'll take one right now! How do you insert a link, what program do I use?
                    • 9479
                    I would love to have a FE Rigger this size to chase the guys at NAMBA 20
                    • jpracing1997
                      • Mar 2008
                      • 535
                      Pics of rigger
                      Here's the pics of my rigger 36 inches by 20. Built by Paul Packmayer! Power suggestions welcome to get me in the 70 + mph club. I have a hydra 180 hv and all the batteries I need. Thanks
                      • m4a1usr
                        • 2032
                        That was me. And you probably mean prop walk. Not wash. I saw Chris commented in your original thread about maybe needing a wheel as big as 65mm. I tend to agree with that sizing for running at 28k rpms. I'm not a racer, not record holder. But I do understand the mechanics.
                        I guess I have to ask the obvious question, why not run 5S using the 1521/1.5D? If you have room for the batteries then bump up the RPMs. Then you can keep the prop size down.
                        John
                        • jpracing1997
                          • Mar 2008
                          • 535
                          Can I run 5s with the 1521 1.5d and not go over on my amps with a smaller prop? And i meant walk.
                          • jpracing1997
                            • Mar 2008
                            • 535
                            Yeah i understand. Bigger motors, more torque, bigger props, less rpm! Just worried about amps
                            • jpracing1997
                              • Mar 2008
                              • 535
                              I need more props also, I'm gonna get the ones Fluid suggested and try again. The 447/3 did alot better than the 1747. Both props have been worked before I purchased them! I just wanna learn while I play around with this setup and try not to burn up some $$$$ at the same time. Thanks for all the help guys.
