Bring this thread back to life. I went to put the stringer on today after being off since day one. I went to start trimming everything out neutral (trim tabs/Struts angle) and the freaking stringer is below the hull as well just like the trim tabs where. Problem is the whole inside of the boat including the stuffing tube is fiberglasses over. I am clueless on this one.
HK Vanquish
In looking at all of the pics and you do have several options. Just none are decent. The quick fix is taper (file the down the diameter) the back of the stinger so that you reduce the aluminum extending below the hull. Totaly sux to mod the hardware but may not be a bad option. With a gentle taper towards the prop you might get away with doing the least amount of work.
But to do it right you need to remove the stinger, cut out the dang stuffing tube, bring it up a 1/4" and reglass. Much more work since your going to need to redrill all the holes. But it will be 100% right. No half way meaures.
Not what you wanted to hear right? I know. I been burned myself, didnt expect to see what I got. Good luck on your decision. I myself have been toying with buying one. The price is so damn good! Hard not to toss $130 or so bux at a new 40" mono!
JohnChange is the one ConstantComment
Man that sux! Normal stinger install (for me at least) is having the stuffing tube approx 1/4-3/8" above the bottom surface. Those clowns went all the way to the bottom. Shows how much they know.
JohnComment
tiqueman has a persuit with a 4082 and a 180a turnegy and m445 prop with the card of capassitors and no heat prob at all....MY RETIREMENT PLAN?????.....POWERBALL
74 vintage kirby clasic hydro, pursuit mono, mg, 47'' mono, popeye hydro...Comment
* If you wanna sell it let me know.... I will gladly take it off your hands.Comment
thanks for pointing that out diesel
when I saw your picture, I instantly gone to my box and check the boat for the same defect, it is a bit below the hull but very little, not as much as yours, got lucky on that, and I haven't done anything yet to it so I can still do a proper job if I'm willing to go that far, but I'm also a sport runner, no racing, will adjust the trim tabs, do a quick fix on the surface drive and put a layer of FB in it to make it solid
will continue to come back to the thread to see what is new about this hull
I can't build them all at the same time so the boat is on the waiting list for now... lol (3 heli, 6 planes, 3 trucks...) :pHK Vanquish, Leopard 4082 1250kv, Turnigy Marine 180A ESC, Turnigy 5000mAh 6s 40c, Octura x447 = 40mphComment
Diesel....................just try running it as is to see what you have to work with.....cant hurt. The problem you will find is that it will literally ride on the prop...........which will give you torque roll problems, and it will not corner well.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
For now I'll just keep it in storage, I'm waiting for a 1717 motor mount anyway... But keep in mind that shipping something that big from Canada might cost you more than getting a new one from HK.Comment
I may have to go to a bigger bullet connector. I have 6.5s and it says they should fit 8 gauge wire but those esc's leads are some damn thick it's gonna be a pain in the butt to fit those in a 6.5 cc bullet. I do have some open end bullets but there 5.5. I don't want to step down I rather step up. I still planned on running 5.5's on the battery end considering all my batts and chargers are currently 5.5. Any thoughts on this?!?Comment
That makes sense. I guess I will just grab another one of these from HK when they come back in stock then. Next one will the Leopard 4082 in it. I guess I'll just use this as a $70 test hull.Comment
Ok back on track with this. I was able to elongate the holes and move the stringer up. It's not as high as I want, but I hope it works ok for sport boating. I was aiming to make it flush with the bottom of the hull and got a little lucky and was able to get about 1mm up. Not a lot but ANYTHING is better then the way it came. So far stringer, both trim tabs and 1 (port side) turn fin all had to be moved and rudder braket modded also hull strengthed with FG. I ran a bead of RTV around the base of the stringer and got trimmed out neutral.
I looked to try Johns idea of grinding a little material off and the wall thickness of the strut on the part nearest the transom is just way to thin. I was afraid to do it. Doesn't appear to have misaligned the stuffing tube with the strut. I had some room to work with because of the way the stringer was made. So flex should slide in no problem... So I prayComment
These hull must be coming from a different factory than the Osprey which is the same hull & hardware. As the Osprey trim tabs on the one ive got are between 1.5mm above the hull bottom in their lowest position & 2.5mm above at their highest position & the bottom of the stinger is around 2mm above the hull. Martin.Comment
