Mystery 80 ESC
  • H&MWill
    • 623
    Mystery 80 ESC
    I have come to the conclusion that these are 100% pieces of junk I have sat here for the last 4 hours trying to program this worthless a** thing and nothing. It wont come off of soft start up and I am done. It is going to give me great pleasure to smash this worthless piece of crap into a million pieces. Sorry just ventin!
    Many issues!!!
  • andym
    More Go Than Show Prop Co
    • 2406
    Yes the chineese ones should only be purchased with setting box or they become a pain in the arse! You smash that sucker and go buy a castle, go man go!!!!
    UH have some cheaper ones with good program options.
    • H&MWill
      • 623
      Oh dont worry I am done with cheap short cuts. I am done cuttin corners. If I dont have the extra cash at the moment I will wait. The bad thing is I know better. Oh well it is starting to snow and that is where it is laying. LOL
      Many issues!!!
      • ED66677
        • 1300
        does it play any sound when you turn it on?
        if throttle is idle when turning it on you should hear a little music and then one or two bip depending if brake is on or off
        if throttle is WOT when turning it on, it will play a different music and then 9 series of bips and bops as following...
        1) - - - Brake On
        2) -- -- -- Brake Off
        3).- .- .- NiCd/NiMh
        4).-- .-- .-- LiPo
        5)..- ..- ..- Soft Startup
        6)..-- ..-- ..-- Hard Startup
        7)...- ...- ...- Soft Timing
        8)...-- ...-- ...-- Hard Timing
        9).... .... .... Reset to factory settings
        pull the throttle to idle to validate a parameter
        Emmanuel
        • H&MWill
          • 623
          Thanks Ed I have went through that sooooo many times its not even close to funny. It came with those exact instructions. All of the settings will change except soft startup. I wouldnt care about it but the only way to get the boat on plane is to hand launch it and if I wanted to do that I would just go back to nitro. I am sure it is a bad unit but I will never buy another. Thanks for trying to help me out. Sincerely Will
          Many issues!!!
          • ED66677
            • 1300
            well... I have 3 of these ESC and never really noticed any difference when changing from soft to hard startup... got them for 15£ average!!!
            but you are saying that you really need a hard startup to get the boat on plane???
            Emmanuel
            • Rex R
              • 992
              if it is a 3-point hydro, then yes it needs a hard start. anything else and it does a submarine imitation :).
              • Steven Vaccaro
                • 8721
                I wont purchase any esc without a computer or handheld programmer. Even castle esc's can cause me a issue hear and there when trying to program with the trigger. I have a hard time with beeps, blips and pauses. Hopefully I never have to use morse code at any high rate of speed!
                • H&MWill
                  • 623
                  Yeah its a H&M Viper with stock SV motor. With mystery it does just Rex said. Im done with it. I am still hearing all the beeps and musical notes LOL.
                  Many issues!!!
                  • ED66677
                    • 1300
                    got you! throw it away!
                    the best one I have needs almost 1 second after WOT to have the motor spining correctly, during that time, the Mystery is trying to catch the motor rpm!!! the 2 other I have are even worth, during that second, the motor spins forward and reverse and then spins all right!!!
                    in any case you wont make any good with your Viper!
                    Emmanuel
                    • Tunda
                      Eh no steal my slipa
                      • 754
                      Man i just bought one from a guy in the swap shop and just orderd 2 pixstix for it
                      dont tell me i just wasted 50.00 plus 14.00 for the pixstix........
                      Hawaiian Tunda
                      • txboatpilot
                        • Oct 2007
                        • 1494
                        I got one to work fine after using pistix and reading this....http://www.rcuniverse.com/forum/m_5568120/tm.htm
                        Nothing like keeping you lipos warm and your prop wet!!
                        • Tunda
                          • 754
                          thanks for the info...............
                          Hawaiian Tunda
