Eagle Tree - What the heck is this???
  • lectriglide
    • 538
    Just downloaded some Eagle Tree data from my Geico and Fastech (just curious) runs a couple days ago. Setup on the Fastech is stock 1500 PB motor, X642, and Turnigy 90 esc with an additional Rubycon 35v 1000uf cap. Batteries were Turnigy 2s 5000 20c's x 2. Amp pull shown was expected, but what the heck is with the voltage spike? The batts weren't hot, checked out at 3.75 or so volts per cell. Didn't blow anything, can't really explain or really believe the data. Anyone have any suggestions?
  • Himalaya
    • Apr 2009
    • 251
    Unreasonable data. Probably faulty data caused by very strong EMI. Have you noticed a UFO passed by your pond?
    • lectriglide
      • 538
      Been wondering why the ducks just hover over the pond??
      • Alexgar
        • Aug 2009
        • 3534
        maybe the prop went airboure and when it recaught and spike the amps
        • ezhitz
          • Aug 2009
          • 428
          Just a thought.If your running 4s why does your graph start a 20 volts that would seam like each 2S pack would of be around 10 volts each? Could be a faulty reading from the start or I read the graph wrong
          :canada
          • lectriglide
            • 538
            The left scale is amps, the voltage is to the right.
            • Himalaya
              • Apr 2009
              • 251
              Have you used this Eagletree any more? did you find the same phenomenon again? You can try it in live mode with a battery connected. Then try gently knock it, shock it, bend it.
              I am guessing this might be a sign of a hidden hardware problem, possibly a bad solder joint on the lower resistor of the voltage devider network.
              • keithbradley
                • 3663
                Water can do the same thing. If it got wet at all, or your esc got wet, you can get some crazy readings.
                www.keithbradleyboats.com
                • lectriglide
                  • 538
                  Here is a short run of MG right after I removed it from the Fastech. I installed a Medusa 36-60-2000 and wanted to check the amp draw since I had a T120 in it. Removed the T120 and went T180 when I saw the 115 amps it was pulling. GPS @ 44.8 with a detongued x442 . Everything looks OK to me on this log.
                  • lectriglide
                    • 538
                    The stock esc is in the tupperware type container and had no water in it. The hull did have maybe a shot glass worth of water in it, but I attach the eagletree to a half cut pool noodle to keep it off the bottom of the hull. I guess there's a slight chance considering it was bouncing off the waves and ripples. It wasn't wet when I removed it but could be... At least you've given me an idea of what might have happened.
                    • tsenecal
                      • 58
                      my castle creations hydra 120 spiked like that right before it had a meltdown. I sent the data logger file to prove that nothing i did caused the ESC to die.
                      • oscarel
                        • Dec 2009
                        • 2127
                        I would suggest that you conformal coat it so you don't damage it.
                        • Gary
                          • Jan 2009
                          • 1105
                          All my Eagle Trees will have a glitch like that or something else now and then. Hell my boat showed a speed of 1,850mph one day !!!!!!!!!!! Everything else was fine.
                          H&M 1/8 Miss Bud 73 mph
                          Chris Craft 16 mph
