Aquacraft Motley Crew up on the AQ site!!!
Your Correct Doby, I was running the 1800KV motor in mine. However, I have not had a chance to use the new motor cooler design.
I spent the entire racing season (4min heats) running the 1800KV motor, original UL-1 style motor cooler, FlightPower 4350 4S2P, and an Octura 440/3 and my set up never got "hot" (over 110F)
And you are right Doby... I think it run really well too.
Later,
MikeComment
No think'n about it Mike. The boat does run well. I can't wait to see this and the PB cat raced together. We know the Motley works so this summer I say let it all hang out. You know Spence wont be cutting you any slack.
Did the final molds include that adjustment you guys were fiddling with? I looked at Grims boat at the nats but I can't remember. His ran really well too. I think he left some speed on the bench much like you did most of last summer. The nats just wasn't the place to play with a ragged edge prototype setup. That's more my kinda thing.Noisy personComment
Nice and clean inside with lots of room to work. Just finished building a
53" gas skater, be neat to have a little oneComment
*Jay did your prototype have that new water jacket on it? How were the temps on the m445.
Def looking forward to this cat!!!Comment
Here is the Aquacat running the offshore course (with the extra bouy) at the NAMBA 2010 FE Nationals in Greeley Colorado.
If I remember correctly that heat was pretty much a full field, and the water was chopped up pretty good (hence the phrase racewater), also in the video you can see the storm clouds brewing, which further deteriored conditions.
Grim had the aquacat cruising pretty good; however there is some drama down course as you will see in the video link posted below.
http://www.youtube.com/watch?v=AMDntNj5Ztw
Smacked that other boat pretty good at the end.Comment
What a clean looking setup! This is the way a boat should look inside!!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Sure does look to be a winner! And though I don't like the theme it could be worse.
Justin Beiber!If my boats upside down then who owns the one I thought I was driving the last two laps?Comment
I hope the hull is better quality than the UL-1! While the boat runs great, I never could figure out why AQ made such a crappy weak painted hull when they could have had a gelcoated strong hull for about $20 more!Mini Cat Racing USA
