Twin drag cat
  • Doug Smock
    Moderator
    • 5272
    #31
    LOL It's ALL fun Chris.
    I started out as a scale boater myself then got the speed bug. It's been all down hill since.
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • ScarabChris
      • Oct 2010
      • 752
      #32
      Doug
      Hey Doug, definately all fun. I'm sure you have seen my 54" Fountain build. Its the perfect combination of scale and all out speed. It looks like a real Fountain (especially once I get the wrap on) and at 30 pounds RTR it aint doing bad at 60 MPH.
        • 9488
        #33
        What about twin CC1520's on 8s in this 35" hull?
        • dasboata
          • Dec 2010
          • 3152
          #34
          You want to buy my hull and try
          • seedoobob3
            • Dec 2010
            • 36
            #35
            Hey Chris, Peter is building my twin mount side by side 1717's now, set my rails to 6" to get both centered betwwen rails, straight out stuffing tubes to twin inline strut/rudders from aeroM, he does a great job.
            • dasboata
              • Dec 2010
              • 3152
              #36
              I e mailed him I not sure I am going to go threw with this hull I have been told it is way to small
              • blizard05
                • Jun 2007
                • 576
                #37
                Come on Chris,don't give up,you and I both know the DC can do 80+ Wally did it with gas. Go ahead and womp him with an electric set up.
                America home of the free, thanks to the brave [/url]
                • Punisher 67
                  Ignore list member #67
                  • May 2008
                  • 1480
                  #38
                  Yup I would consider a bigger hull , a lot bigger...................
                  • Punisher 67
                    • May 2008
                    • 1480
                    #39
                    This dual motor schematic was done by Racemechanix on our forum here , me and Tyler have worked on some joint projects , this is Seedoobobs mount
                    now nobody get to excited this has yet to be milled , I should have the run written today and will run it sometime next week............
                    • dasboata
                      • Dec 2010
                      • 3152
                      #40
                      Nice mount !! I would prefer something I could mount to the rails do you guys ever use rubbers Isolators to mount you motors ??
                      • Punisher 67
                        • May 2008
                        • 1480
                        #41
                        That mount would bolt to a set of 6" rails , you don't see them in the picture but it would have two mount holes on each end as to be bolted to a stringer system , I have yet to see anyone use rubber isolators for electrics
                        • dasboata
                          • Dec 2010
                          • 3152
                          #42
                          I like the mounts BUT there is alot of extra material there you can probleby reduce the size and cut the weight in half also on the alum tubes you might want to concider CF for that WOW effect that's what I would do to mine I already have e mailed Peter Let me see what happens PM me a ball park price I don't need the alum tubs and I would want them reduced down quite a bit what do you think thanks chris
                          • Punisher 67
                            • May 2008
                            • 1480
                            #43
                            Hello Chris
                            I am Peter Z..........Why don't you draw up what you had in mind , I also don't work with CF , One day maybe
                            • dasboata
                              • Dec 2010
                              • 3152
                              #44
                              Hello Chris
                              Sorry Peter My mind is blown too much going on can you tell me how the rear of the motor is secured ?
                              • Punisher 67
                                • May 2008
                                • 1480
                                #45
                                Not a problem Chris
                                Here is a single 1717 mount , the Castles are a little more difficult because of the wires at the rear
                                I install a double O- ring buffer at the rear
