HPR Mania - Version 2011
  • ManuelW
    • Oct 2010
    • 756
    #46
    Hello Guys,
    thanks for the very nice comments. As written above I had the decals made and put on from a good friend of mine. So I shipped him the hull as well as some pictures and drawings, he did the complete work for me. But I think he uses some high quality material for the decals which he can "bend" over 3D surfaces to a certain extend.
    And for the speed, the owner wants to use LMT 1950/6 with 2090kv on 5S or even 6S lipo so it won't be really slow...
    I'll try my very best to get the first HPR135 running this Saturday, some hopefully I have some news in a few days. Motors, as well as ESC's and Lipos are already here, "just" has to be built together.
    Best regards,
    Manuel
    • ManuelW
      • Oct 2010
      • 756
      #47
      Hello Guys,
      today some more infos about the HPR 135 I build. Took my about 13 hours of work on Friday but I did it and on Saturday was its first test run.
      The Setup:
      Aim for the boat was to get an extreme power to weight ratio with a setup with very reliable components. It should not be something for highspeed but something around 90mph at very good acceleration.
      Therefore the setup I chose:
      motors: 2x LMT 3040/9 HiAmp LK with water jacket and rear support
      ESC's: 2x Modellbau-Regler AS 26.200 "special edition"
      lipos: 2x 8S1P Turnigy Nano 5000mAh 45C
      props: Octura X457
      Last week the rest of the components arrived, here some pictures of the two drives:
      Here a picture to get a feeling for the size of the engine:
      As I wanted all the cables as short and as efficient as possible I didn't really like the 2x 4S1P lipos on each side with the thin 10AWG cable. Therefore I opened all the packs, desoldered all the cables and directly connected two 4S packs to get one single 8S1P pack. Then I soldered some nice 8mm² (~8AWG) cables to the lipos, used some nice 6mm LMT bullet connectors and with some special tape I shrinked them to the sledges of my lipo mounts.
      And here a picture of the result, I'm quite satiesfied as these are compact packs:
      • ManuelW
        • Oct 2010
        • 756
        #48
        Then I build everything together, I'm sorry if there is still some mess around in the boat but I had not enough time to care about the final layout and make everything fine. I think it still looks quite neat.
        For the setup I chose 8S1P per motor as these fit in each sponson quite nice and to get the cables as short as possible. All power cables between ESC and lipo and between ESC and motor are 8mm² (~8AWG) and 6mm LMT bullet connectors. The ESC is rated with 200Amp but it can handle quite more than that I'd say. The used LMT 3040/9 have at 8S lipo their maximum efficiency at about 220Amps which means a power output of about 6500W per drive. In combination with the Octura X457 this should give some really nice performance. And the best of all, the RTR weight of this boat is just 9kg which is very light I'd say --> nice acceleration!!
        Here some pictures:
        • ManuelW
          • Oct 2010
          • 756
          #49
          As said on Saturday there was the first test run. On the maiden run I used a pair of Octura X447 R/L which is quite small. Did go quite well until some water beside the receiver caused some cut-off. Had to dry it and about an hour later I did another test with Octura X457's. Sadly the video is not that good and couldn't give full throttle. But the next time I'll adjust the drives and the CG to see whats what ;-D
          I hope you enjoy it!
          Best regards,
          Manuel
          Here the first run-out:
          Or as a link:
          • johnf
            • Dec 2009
            • 1078
            #50
            Awesome!
            Catching Air!
            • ManuelW
              • Oct 2010
              • 756
              #51
              Last Sunday was the 4th test run, I think I'm coming closer:
              Best regards,
              ManuelW
              • tiqueman
                • Jul 2009
                • 5669
                #52
                Looks great Manuel!
                • ManuelW
                  • Oct 2010
                  • 756
                  #53
                  @ tiqueman: Thanks for the comment!!
                  As the design of the HPR 135 "Lightweight" is already fixed, I ordered a special plexi glass boat stand from a friend of mine:
                  • ManuelW
                    • Oct 2010
                    • 756
                    #54
                    An another HPR C5009 "Mystic-Style" I build this year, I really love these hulls!!
                    HPR C5009 "Mystic Style"
                    original HPR Hardware Kit: drives, rudder, hydraulics, motor and servo mount
                    2mm CF lipo rail system
                    specials: Not-Aus System, blue colored seams (all reinforced with GFK sheet), hatch locks and rear support for the motors.
                    I hope you may enjoy the pictures!
                    Wish a nice evening,
                    Manuel
                    • ManuelW
                      • Oct 2010
                      • 756
                      #55
                      • RaceMechaniX
                        • Sep 2007
                        • 2833
                        #56
                        Great build Manuel, keep the pics coming.
                        Tyler
                        Tyler Garrard
                        NAMBA 639/IMPBA 20525
                        T-Hydro @ 142.94mph former WR
                        • tiqueman
                          • Jul 2009
                          • 5669
                          #57
                          Seriously Manuel, you have too many of these. I think one needs to come to my house. You dont even have to build it. In regards to your PM, I see the tray more clearly now. Ill do mine exactly the same.
                          Thanks!!!! And if you need my address again..... Ill even be nice and pay for shipping.
                          • alerc
                            • Jun 2008
                            • 3
                            #58
                            Hi Manuel!
                            The last one Mystic HPR is mine!:D
                            thanks Manu! Great Job !
                            Ale
                            • ManuelW
                              • Oct 2010
                              • 756
                              #59
                              Hi Guys,
                              thanks for the comments. And for all the HPR fans who may want one. If you are interested in a hull/boat from Hanspeter you may also contact me as I'm quite a good friend of him.
                              Best regards,
                              Manuel
                              • Boaterguy
                                • 1760
                                #60
                                Quick question, it seems the motors have 6 connectors (leads) on them, why is that and how do they work?
