Hey guy, I have a 25" artr brushless boat!! It's handlaid fiberglass and I am just wondering if there is any way to prevent getting holes in the hull??? I found a hole that is only about 1mm in diameter which is tiny and won't decrease the performance of the boat in any way!! I just used a bit of araldite both sides of the hull to patch it up!! Answers will be much appreciated!!! Also I will be upgrading the esc to a 120amp one from hobbyking and a 380 7xl motor with only a small 380 water cooling jacket cause the long ones were out of stock!! They will be used on 3cell!! Will they both handle the 3cell without overheating??? Also I have the old 380L 2881kv in it now and had a 30 amp car esc in it!! I have a 3Cell 2200 mah battery!! I was running it and it only ran for about 1minute I was begging to think there was something wrong with the motor so I bout the XL !! Would it be the batteries or the motor because I am sure they would last longer than 1minute???? Help will be much appreciated
Thanks alot
Matt
Thanks alot
Matt
