slicing and splicing
  • RIPFENCE
    • Sep 2009
    • 1332
    hi all,
    i had 2 mishaps early this spring from not securing my on/off switches on 2 esc's..i have a turnigy 180 and a swordfish 240 with the wires that have been cut from getting into the shaft coupler while at speed...i hate to throw these things out..what is the best way to reconnect the tiny black wires to repair these esc's...if i cannot do it then i will have to put them in the swap shop for real cheap...there are no heat shrink connectors small enough to make a good connection..i am sure these esc's are fine if i can reconnect the wires
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    You got a picture for us to look at Rip? I think it should be no problem.
    FE BOATING: Less like a hobby and more like an addiction!
    • forescott
      Hopelessly Addicted to RC
      • 2686
      The swordfish 240 is not repairable. I will take it off your hands for 50-bucks!!
      • RIPFENCE
        • Sep 2009
        • 1332
        here is the problem with the swordfish...the t180 has both wires cut
        • Doug Smock
          Moderator
          • 5272
          Take the switch apart and solder the wires directly to the switch Rip.
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • blackcat26
            High Speed Junkie
            • Sep 2009
            • 1598
            I agree with Smock. If you don't wanna do that a less clean looking way would be to slide some heat shrink tube over the cut wires, solder and shink tube over the connections. Smocks idea is much more clean looking tho.
            • RIPFENCE
              • Sep 2009
              • 1332
              doug great idea..man i feel retarded now!!! thanks guys sometimes the simplest things evade my thought process
              • Alexgar
                • Aug 2009
                • 3534
                radio shack sells 2 mm heatshrink????? tiny but made for this and i think hk sells it to they sell 2mm bullets
                • RIPFENCE
                  • Sep 2009
                  • 1332
                  ok i will keep this in mind in case i have trouble with my switch..thank you
                  • LarrysDrifter
                    Big Booty Daddy
                    • May 2010
                    • 3278
                    Id ditch the switch and solder both wires together.
                    • NativePaul
                      Greased Weasel
                      • 2761
                      Me too, cut em real short twist together and solder, or ditch the wires altogether and put a solder bridge on the board.
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        Yep.No need for a switch,unless its just a personal preference.A friend of mine has a CC Sidewinder in a SC truck and it kept glitching and wouldnt run full throttle.He called Castle,and they said to cut the 2 on/off switch wires and solder them together.Sometimes the switch is what causes problems with esc's.Plus,theyre just not a nessecity anyway.
                        • bwells
                          • Jan 2009
                          • 842
                          I agree, ditch the switch and solder the 2 wires together or get another switch from radio shack spst and your good to go
                          • m4a1usr
                            Fast Electric Addict
                            • 2038
                            Where did you get a Turnigy 180 with a on/off switch? Did the first gen or car versions come with a switch? I have never seen one? Sounds like a cool feature. All my MGM speedos have them. It makes it nice to have that feature cause you can wire the switch function to the outside of the hull making it easy to disable the boat upon removal from the water. Then you peel off the tape, take the batt leads off,yada yada.
                            John
                            Change is the one Constant
                            • RIPFENCE
                              • Sep 2009
                              • 1332
                              sorry it was not the on/off it was the main red/white/ black lead on the turnigy..i have not tried using the kwik switch mount outside the hull yet. i know a lot of boats have them on here but i get worried about water getting into them somehow
