Sorry i cant anwser the power thing, i can build a boat the power stuff goes over my head ,,I hope these guys will chime in soon with an answer for ya!!!!
My factory Genesis came with the Sordfish 120 esc and on the factory motor the esc is fine and runs cool but the motor gets hot on 2x2s 5000 lipos and a TFL prop i gess around a 442 size..
Have you checked the prop shaft to make sure it spins freely? Mine was very, very tight from the factory. This could be causing the motor to heat up very quickly and put lots of strain on the electronics.
I ended up boring the strut out on mine to 3/16" to get rid of the square drive and be able to use my other props instead of buying new ones or using an adapter.
Well if the motor is rated at 80amps then a 120amp should be plenty.... Am I right? Why would I need 100 amps extra? I will already have 40amps... Please explain maybe im not getting something here..
After all is said and done, more is said than done.
No, youre not right. The motors can and will pull more than 80 amps. It isnt as simple as a "rating". I's dependant on input voltage, prop size, driveline friction, ride attitude of the boat, and water conditions.
