Genesis Build
  • dddmx3
    • Mar 2010
    • 233
    #31
    I always update the first post, look at the motor.
    (twin cc1512's)
    After all is said and done, more is said than done.
    • dddmx3
      • Mar 2010
      • 233
      #32
      Do I need to reinforce the inside with carbon fiber?
      Hull's in painting right now.
      What do you guys think about the rudder? Is a center-mounted one fine?
      Also,
      How much speed would I get out of a 4s2p setup?
      and how much more speed I would get out of a 5s2p setup?
      Thanks for your guy's help so far!
      • Rumdog
        • 6453
        #33
        5s will give you much more speed. I'd say with x442's around 60mph if set up corretly. For SAW runs 6s is going to make it really boogie.
        The single center mounted rudder is the way to go with twin cats.
        Re-inforcing the entire hull is not neessary. Reinforce the areas where you mount hardware and you should be just fine.
        • dddmx3
          • Mar 2010
          • 233
          #34
          Thanks! Guess I'm going with 5s2p..
          What about struts? Any suggestions?
          • dddmx3
            • Mar 2010
            • 233
            #35
            Purchased 2x Castle 1512 1800kv's
            Just waiting for them to come to my door.
            Boat has been painted. Click here to view pics!
            Still making the struts... So far only done with one strut.
            For water pickups, (< < click there to view ) can I go with 2 of these? If so where should I put them in? Towards the middle of the hull or the very end of the hull? (one on each side)
            • HYDROJERRY
              • Jan 2010
              • 2503
              #36
              the very end of the ride pad....at the rear of the boat..
              • kjohnsiii
                • Oct 2010
                • 116
                #37
                Sweet build! Are you in western wa? Would like to see her in action when she's all done.
                Kenny
                • dddmx3
                  • Mar 2010
                  • 233
                  #38
                  You mean as closest to the end as possible right? Because on a genesis hull they can't go on the very end...
                  Yes, I'm around the Vancouver-Portland area...
                  • kjohnsiii
                    • Oct 2010
                    • 116
                    #39
                    Cool
                    • HYDROJERRY
                      • Jan 2010
                      • 2503
                      #40
                      this is blackcats twin Geico,,,but you can see the water pickups here,,his are alittle forward cuz the flexshafts are in there but yeah!!!
                      • Rumdog
                        • 6453
                        #41
                        Where are you going to get Stinger struts?
                        • dddmx3
                          • Mar 2010
                          • 233
                          #42
                          Thanks hydrojerry!
                          I'm using a friends lathe machine to make 2 stinger struts...
                          Attached is a picture of a lathe for anyone who doesnt know what it is!
                          Actually it's his workshop!
                          • dddmx3
                            • Mar 2010
                            • 233
                            #43
                            I think I will go with the 120amp swordy esc's instead of the 200amp...
                            Do I really need that much headroom?
                            • HYDROJERRY
                              • Jan 2010
                              • 2503
                              #44
                              My factory Genesis came with the Sordfish 120 esc and on the factory motor the esc is fine and runs cool but the motor gets hot on 2x2s 5000 lipos and a TFL prop i gess around a 442 size..
                              • HYDROJERRY
                                • Jan 2010
                                • 2503
                                #45
                                PS if you home made struts turn out good enough i may need you to make me some for mine!!!
