Genesis Build
  • dddmx3
    • Mar 2010
    • 233
    Oh I see. Thanks for your input (:
    After all is said and done, more is said than done.
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3278
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        Originally posted by Diegoboy
        That is an excellent option, I agreed to the "headroom" comment
        • dddmx3
          • Mar 2010
          • 233
          Cool cool (:
          When could I get some mounts to fit inside the hull?
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            • dddmx3
              • Mar 2010
              • 233
              Could I go 8s? 4s to each side?
              • keithbradley
                • 3663
                The "s" in 8s or 4s stands for "series"...that might clear up any confusion you may run into in this build.
                www.keithbradleyboats.com
                • dddmx3
                  • Mar 2010
                  • 233
                  Well I know that.. What I'm saying is if the esc can 6s maximum why not have 4-6s to each esc instead of 3s?
                  This is a SAW boat anyway?
                  • keithbradley
                    • 3663
                    Now Im confused...if you already knew that...then that means you are planning on running 8 lipo cells in series? What were you talking about 8s?...you said something about 4s per side so I assumed you just didnt know the difference. Were you considering an actual 8s setup?
                    • dddmx3
                      • Mar 2010
                      • 233
                      Should I say 4c to each side for 4 cell lipo?
                      I'm saying if I power a 4 cell lipo to each 200amp swordy then technically wouldnt that be a 8 cell setup?
                      I could even go 12 cell?!
                      • keithbradley
                        • 3663
                        If you ran 4s to each esc, that would be 8 *CELLS* total...but not not 8s. Thats what I was saying in the first post I wrote. 8s means the cells are in series, meaning you are running at a nominal voltage of 29.6 volts. Your suggested setup would be a 4s setup, because you would be running 14.8v (4 lipo cells in series). For example, 6s2p means a total of 12 cells, but its still a 6s setup.
                        The confusion here is the reason I posted in the first place. I wanted to help make sure you didnt have people advising you on a 30v setup when you are only running 15volts.
                        Now that thats out of the way, most people run 4s maybe 5s on the 6s rated escs. They can be ran on 6s, but most people avoid running an esc at its max rating to prevent premature failure.
                        • dddmx3
                          • Mar 2010
                          • 233
                          #27
                          How much speed would I get out of a 4s2p setup?
                          (technically I think 8s)
                          and how much more speed I would get out of a 5s2p setup?
                          (again, technically I think 10s)
                          • Make-a-Wake
                            FE Rules!
                            • 5554
                            #28
                            As stated before...................4s2p is not 8s. Its 4 series, 2 parallel which is 4 x 4.2v = 16.8v. Two sets of 4s batts, so your mah is doubled.......not the voltage.
                            • dddmx3
                              • Mar 2010
                              • 233
                              #29
                              Thanks Make-A-Wake!
                              back to my original question:
                              Also, Will I need carbon-fiber reinforcement? I found this...
                              P.S. Thread continued on next page...
                              • Make-a-Wake
                                FE Rules!
                                • 5554
                                #30
                                What motor/motors are you referring to in these setups................5 or 6 different motors have been tossed around on this thread.
