i actually have a mean machine on order..
Aeromarine dont seem to return emails though and dont know when to expect it.
I have no luck with rc boat companys when it comes to emails.
My buddies cat is fast in a straight line but cant corner very well.
Thanks!
Rolling over or sliding out.. Whats it doing?? If it wants to slide, try a deeper rudder. I have a twin set up and had a single. Both cornered very well IMO.
Keep the offset rudder on for sure.what i do to all my cats is place them flat on my set-up board,which is a cheap fold out 2x3 table with a notch cut out for the rudder/strut,and look at the inside edges of the sponsons/ride pads.they should both be sitting relatively flat on the table,if not i will build up the ride pads with body filler and sand them so they are pretty uniform,but the trick to make better handling is to get the inside edge of ride pad sharp by sanding the body filler with a sanding block and getting a nice sharp edge on the inside edge and bottom of pad.that will make a tremendous difference in handling in the turns.good luck
