Proboat tip FYI
  • tiqueman
    • Jul 2009
    • 5669
    Proboat tip FYI
    Some of you may already be aware of this. I was one who was not and paid a small price. Trying to remove a set screw out of the coupler on a proboat motor often seems like and endless task the ends up w/ a drill or dremel. I went the way of a drill a couple days ago and ended up with a 1/8 drill bit in one side of my finger, thru and out the other. Its not comfortable, dont try it.
    Apply a heat gun or soldering iron to the coupler. PB uses some type of thread lock on thier grub screws. Looking at it, I would never have known, as there was no evidence of it protruding from the top of the threads. I judt thought it was cranked on thier super tight. I had another Proboat motor I got from a member who sent it w/ the coupler b/c he could not get it off. Boomer was kind enough to share this info in another post of mine about heat. I tried it on the other motor and w/ in 20 seconds, the coupler was off. I feel its something PB should state in thier literature in the maintenance section or something...
    Anyway, just for those who didnt know or didnt think to try it
    -Scott
    • 8012
    A good tip Scott, thanks. Another good idea is to use a vice to hold the coupler (or whatever has a screw) when trying to loosen a tight screw and especially when drilling. A small clap-on vise is cheap and should be part of any serious FE boater's tool box.
    http://www.amazon.com/IRWIN-226303-3.../dp/B0001LQY44
    Bottom line, we all need to take steps not injure ourselves. A small burn from a hot drop of solder is one thing, but drilling a hole through a finger and risking permanent damage is something else. Be careful out there.
    • tiqueman
      • Jul 2009
      • 5669
      Best part is, I had a vice within 18 inches of where I was working. Just took the short cut and tried to do it in the boat real quick. I think weve all been there, just didnt think about it cause I'd done things like that so many times. Oh well, Lost that battle, still winning the war though
      • chummer
        • 636
        Good tip tiqueman. Funny, I never thought of using a soldering iron.
        "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
        • Darin Jordan
          • 8335
          On this topic, I have made a request to the ProBoat team to ask the manufacturer to stop using loctite on this part. We'll see what happens.
          Darin E. Jordan - Renton, WA
          • GeoVW72
            • Jun 2010
            • 258
            I have encountered this "locktite" several times with other horizon hobby products and even traxxas products.
            I believe it to be a simple assembly error, instead of using locktite they are using thick CA or something similar.
            With my 8ight-e the diff pinion couplers were literally glued to the pinion and required heating, with a soldering iron in my case. The set screw came out, but the coupler would not let go because it was glued on.
            Also had a problem with a traxxas stampede vxl, one wheel nut was glued on and in the process of trying to remove it I killed a hex and spindle.
            Whatever this is, it has no place on an r/c vehicle
            Team Boca Bearings
            S&G Design
            • tiqueman
              • Jul 2009
              • 5669
              Nice recommendation by someone who actually will have some pull on the subject. Thanks Darin "Yoda"
