i have a temp gun but since they puff i'm thinking hot anyways so i dont bother taking a reading.
Esc and motor temps good.Lipos HOT!!!
DouggieComment
That's because your running 1p. Run 2p and your hot lipos will be cooler and your wallet will stay heavier. Your batteries cannot keep up with the demand of your motor esc. That's why their cool and your batteries are hot.If all of your wishes are granted, many of your dreams will be destroyed!Comment
Had you told us 1P in the beginning we'd have had an answer for you immediately. Hot cells but cool motor/ESC usually means not enough pack capacity. The Castle motors draw plenty of amps. You could be drawing ~140 amps with peaks around 200 amps. I run a Neu 1521/1850 motor on 4S2P in my sport hydro and I draw an average of 180 amps with a larger S230 prop.
How much capacity are you using for each run? That will help determine your actual amp draw. If the packs "puff" then go down, they are not really "puffed" i.e. ruined. Actual pack temperatures would be needed here. Drawing packs down below 80% will usually heat them up pretty hot.
Two and a half minutes is pushing that racing setup. Most P Hydro heats are about 2 minutes long. Plus most folks have no idea how long they are actually running - did you use a stop watch to time your runs?
Bottom line, you do not have a setup appropriate for 1P and over two minutes of running. The only guys who seem to really get away with 1P and high power motors are running 45C/6500 mAh packs and limiting their runs.
The next thing to go will be your ESC - inadequate packs stress the controller a lot....
my lipos do go down after puffing.
I still need to learn the whole mah draw thing.when i go to charge them after they have cooled
they read 3.85 per cell.What do i need to get a mah reading?
I have limited space so i will have a go at stuffing 2 x 2s in her.
Thanks for all the help!Comment
To find the capacity used just record how many mAh you put back into the cells after a run. That will help us to determine what is happening. 3.85 volts is about 50%.
You will gain nothing from using 2 x 2S1P packs in the boat, that is still 4S1P. You need 4S2P. Depending on where your motor is you may be able to put two 4S packs in front of the motor. Or 4S1P in front of the motor and two 2S1P packs on the sides. Here is what one racer did, but I don't know what capacity cells he used.
If you are only using 50% of your pack capacity then the problem is probably too high an average amp draw causing the heat. If you are drawing over 80% then the high heat can be caused by depleting the packs. Both results are related. But we really need to know how much mAh you put back in.
Yes, with 4S2P you'd better hope you never lose the hatch 'cause it will sink. This happened to Mark F in LA last month. He did find the sunken boat though.
