Painting a Vac-U-Pickle
  • JimClark
    • 5907
    Anyone ever use auto clearcoat basecoat paints on the vacuum formed Vac_U-Pickles?
    do they work will they stick well?
    Jim
    Billy Graham
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    Should work well Jim what auto clearcoat paints are you thinking of using? but I do not own that hull..the base primer coat is the critical one with simillar paints applied thereafter
    Douggie
    • JimClark
      • 5907
      PPG Omni can't rmrmber the primer but it is made for the clear coat base coat system
      Jim
      Billy Graham
      • scullyeng
        • 54
        Have your painter add flexible additive to the clear to prevent cracking of the paint.
        • JimClark
          • 5907
          Humm Flexible additive for the clear.
          Thanks I will have to look into that
          Billy Graham
          • Rumdog
            • 6453
            I used Krylon fusion on mine. It is made for plastics.
            • JimClark
              • 5907
              That is an option also
              Billy Graham
              • JimClark
                • 5907
                Called my PPG dealer and they do infact have a product to make the clear more flexible
                only problem is it is $30.00 a pint. Expensive little pint
                Billy Graham
                • dana
                  Banned
                  • Mar 2010
                  • 3573
                  i've had no problems using ppg clear without flex in it. the hulls just dont flex enough to cause a problem. in fact i have never even found an application its ever needed on a car really....
                  • dana
                    Banned
                    • Mar 2010
                    • 3573
                    oh if i were painting raw plastic abs hull i would first scuff hull with soap and water then rinse, second clean with rubbing alcohol, third spray plastic adhesion promotor, wait 1/2 hour and spray basecoat on, lastly clear. thats assuming you are using automotive products thru an HVLP spraygun.
                    • JimClark
                      • 5907
                      Great info Dana thanks much
                      Billy Graham
