How to set strut angle
  • kevink
    • Jun 2010
    • 47
    Hey guys. After reading a great deal of discussion on the forum about properly setting the strut angle, I would like to know if using a stepped hull such as the ekos or apparition, should I start by setting neutral strut angle relative to the overall hull bottom or just with the last step closest to the transom?
    That will depend on the hull. I am not familiar with that particular hull, but the stepped monos I've raced had the strut set parallel to the keel line. Place the boat on a dead flat table surface and adjust the strut to be parallel to the table. That will be the starting point if further adjustments are required.
    • kevink
      • Jun 2010
      • 47
      Thanks. Tried it briefly on my apparition and hit 54.7 mph. Needs to be adjusted. Some. This stuff is addictive.
