1515 1y
  • detox
    • Jun 2008
    • 2318
    Straight-A-Way
    http://forums.offshoreelectrics.com/...=ABBREVIATIONS
    • Simon170
      • Sep 2010
      • 101
      Thank you mate
      Still in dry dock... But planning to get wet soon.
      • electric
        • May 2008
        • 1744
        Every time I have done what was recommmended by Fluid his suggestions have been correct. I have met him at his boat club in Houston and he has a LOT of experience. You cannot go wrong.
          In heat racing I wonder if the Nue 1.5D 2700 Kv motor would be OK to use with 4s power and smaller m445 prop ? It would turn more RPM's for sure
          Yes, too many rpm for heat racing unless it is geared - that's a SAW motor. You could oval race it on 3S okay, but on 4S it would overheat the ESC if it didn't wear out the driveline first. That high rpm and a relatively small prop would not hook up well in turns either. Shoot for a 30,000 rpm maximum for heat racing.
          • sailr
            • Nov 2007
            • 6927
            Most of us around here run our P-mono's with the 1515-1Y on 4S with the X447/3 prop
            Mini Cat Racing USA
            www.minicatracingusa.com
            • steve-b
              • Mar 2010
              • 245
              Would the x447/3 give a higher top speed?
              Im guessing that it would be a little lacking in the turns???
              I dont race in an org, I like speed... Lots of it.
              I do a little racing with my brother, and a couple of buddies just for bragging rights, but its usually "whos the fastest"
              • sailr
                • Nov 2007
                • 6927
                We RACE! We are after SPEED. Turns are fine. Try the X447/3 on 4S! Do NOT use this prop on 5 or 6S!
                Our speeds are are approaching 60.
                Mini Cat Racing USA
                • steve-b
                  • Mar 2010
                  • 245
                  #23
                  Originally posted by sailr
                  We RACE! We are after SPEED. Turns are fine. Try the X447/3 on 4S! Do NOT use this prop on 4 or 6S!
                  • sailr
                    • Nov 2007
                    • 6927
                    #24
                    typo. Should have said 5 or 6S. Corrected.
                    Mini Cat Racing USA
                    • steve-b
                      • Mar 2010
                      • 245
                      #25
                      Im getting 55 with a HK 2200kv, like i said ill try the three blade with the Nue and see how it goes. Would like to see more then 60 for sure.
                      • BakedMopar
                        No Mo Slipah
                        • Sep 2009
                        • 1679
                        #26
                        I've run the H7 and a 1450 with a 1415 1y. It's way faster than the spec setup. Unfortunatly running only 1p it puts a lot of stress on the electronics. I ended up taking it out.
                        Although I never tried any of my 3 blades with the 1415 1y (which was in there for a short amount of time before going back to the spec setup) I did try it with my spec setups. Results weren't as good as the lifter style two blades.
