Best place for turn fin on hydro?
  • WrknItUp
    • Jun 2010
    • 338
    Okay i just came across a few hydro hulls. Two of them are functional. Except for turn fins. Whats the best side to put one on? The rudder is on the right side of the hull looking at the rear with a ccw spin prop. I need it on the left side sponson correct? Or would it be better with two, one on each side.
    I believe it's my god-given right, To destroy everything in my sight. Cause it never gets dull, it never gets old. The only thing it gets is more bold. Drinkin', fightin', going to the game. In our world it's a way to stay sane. If you're asking me. To have it my way, I'd say that's One fine day. ---- The Offspring
  • eboat
    • Aug 2007
    • 693
    Put the turn fin on the inside side of the way you want to turn
    Hydros only turn one way really good
    Right side to turn right
    Left side to turn left
    • WrknItUp
      • Jun 2010
      • 338
      Okay what about running without any turn fins? I see how one would help it turn in one direction by helping keep the sponson hooked in the water. Would it work opposite without any at all or will it just kinda skip along? Never owned hydros only cats.
      • eboat
        • Aug 2007
        • 693
        It would spin out if you turned at any speed
        • WrknItUp
          • Jun 2010
          • 338
          LOL. Thats not good. So they NEED turn fins. okay well i guess im going to have to fabricate a few then. Whats the most common length on the turn fins? About an inch or so?
          • WrknItUp
            • Jun 2010
            • 338
            Okay so now iv'e got a few turn fins made up about 6 inches in length. How long are the turn fins most people run on hydros, Or is it a personal preference thing. Tinker till its right like always?
            • JimClark
              • 5907
              what hull are you using? how big i it
              Billy Graham
              • WrknItUp
                • Jun 2010
                • 338
                One is a cheap SeaFire hull, and the other is a UL-1. So far ive made 4 turn fins about half an inch wide and 1 and a half inches long about 1.5mm thick. Angled with the hull. Am i going in the right direction? New to hydros lol i cant learn enough in a day!
                  • 8011
                  No, you are way off base on the dimensions. A UL-1 fin copy will work on both hydros, the dimensions and shape are here:
                  http://www.offshoreelectrics.com/pro...od=dh-aqub9515
                  Straight fins should be angled no more than 7 degrees from the vertical, angled towards the centerline of the hull.
                  • BakedMopar
                    No Mo Slipah
                    • Sep 2009
                    • 1679
                    Search for the thread I started "hydro turn fin discussion" their is some good info on their. You want it long enough where it doesn't unhook in rough water but not too long. Normally you want it in the middle of cg. But you can move it to suite the cornering effect by moving foe or aft. Hooks and bends are stuff you need to play with.
                    • WrknItUp
                      • Jun 2010
                      • 338
                      Thanks for all the good info. I got impatient. lol and made a single turn fin for the SeaFire. It works really well as far as handling in chop and hard fast turns so far. I was racing my BJ around the pond and spanking its tail. One thing i dont like about hydros. You cant drive it slow or it sinks the front end or do i have my COG waaaaay off?
