Will two of these Rubycon 35VDC 560uf High Temp. capacitors work on a Hydra 240LV I am running a Neu 1521/1.5D on 4S2P each battery is 50c 5000mah with Octura X447/3
capacitors: what are they for and how many is enough?
CAPs for the T180A
Let me preface this with "I am no expert" and I do not have an EE behind my name, but:
From what I have heard, you can't go wrong adding the same exact capacitors as the manufacturer puts on the ESC.
So, for those of you running the Turnigy/Seaking 180A ESCs, you can buy the same exact capacitors from HERE
Or the high temp 35V 1000uf RX30 Rubycons HERE
He offers free shipping that was fast as well.
My order was placed Monday, shipped from NY and arrived on Wednesday in CA.
BradSoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150Comment
Thats where I get mine but, the 63V ones are special order, lead time, 18-28 weeks.
..and if you ask the cap king, he will reccommend the best ones for our needs. His caps are very well scrutinized and have very low failure rates. Good reading there too.Nortavlag Bulc
The smaller the capacitor the less resistance, therefore using a few small caps is better than using a single large one. Eg; 3 x 330 is better than 1 x 1000. You want them as close to the ESC as possible, this allows them to "filter" the ripple current most efficientlyComment
Hi. I would like if someone can assist me. I bought a TP 5660 800kv and swordfish pro300 and a capacitor bank from rcboatbitz. I want to run it on 8s or 9s setup, can anybody help me by showing me how to connect the capacitor bank. I really don't want to burn up my Esc.
Thank youComment
Very simple. You just wire it in parallel with the power wires.Attached FilesMini Cat Racing USA
Sorry my Iphone fritzed couldnt get you a better pic, but my etti cap bank is right there soldered to the ESC cables.
Aussie 37.jpgComment
Ok. Tq so much for the replay. I have the same bank am i will then solder it in parallel. Should i still use the Std bank that is supplied with the Std300A or will this one be enough for no spark.
Also. Any suggestions on wilt would be the best prop to use for my setup. I bought a octura x455/3 and octura x452/3. The 55 is for 8s and 52 is for 9s. Does that sound right, or can anybody suggest better option.
Tq again for the replyComment
I have heard both ways... Leopard better than TP and TP better than Leopard. Who knowsMini Cat Racing USA
...Should i still use the Std bank that is supplied with the Std300A or will this one be enough for no spark...
..Any suggestions on wilt would be the best prop to use for my setup. I bought a octura x455/3 and octura x452/3. The 55 is for 8s and 52 is for 9s. Does that sound right, or can anybody suggest better option.
I just want fast but reliable.
My setup as follows
TP 5660 800kv
swordfish pro plus 300A
flex 1/4 with 3/16 step down prop shaft
2 x 4s 5000 50c
or
1 x 4s 5000 50c and 1 x 5s 5000 50c
all installed in a osprey 41" reinforced
Hope this can helpComment
Forget the three bladed props, you will probably need a larger thrust cone for that boat than 52mm for best efficiency. The 5660 is not a powerful motor compared to larger, the more common 5692 or 5698, so I'd start with an x455/2 on either voltage. You may be able to go up to an x460, but past that I have no idea. Expect speeds in the 45-50 mph range with a well set up hull.
