cogging
  • Trevor January
    • 30
    cogging
    hey guys
    just wanted to ask what cause cogging in the motor??
    my set up is swordfish 240hv with 2382kv xl with 42x53 3 blade and timming is set to auto and the lv is auto with hard lvc
    not sure what it is, but it ran fine then just started doing it and the esc got hot and the motor got pretty hot not smoking hot but close
    any help would be great
    Trevor
  • Diesel6401
    Memento Vivere
    • 4204
    Search cogging in the search menu.
    Maybe try changing the timing.
    - Diesel's Youtube
    - Diesel's Fleet
    • video200
      • 837
      and check your motor plugs
      • keithbradley
        • 3663
        Did it get wet?
        www.keithbradleyboats.com
        • andym
          More Go Than Show Prop Co
          • 2406
          Water does not bother brushless motors at all, sounds like you started to delaminate the magnets due to the heat, what brand of motor and what hull ?? The extreme motor heat is the clue
          • keithbradley
            • 3663
            I meant the speed controller, not the motor. If the speed controller got wet it most definitely can cause that problem.
            • drwayne
              • May 2008
              • 2981
              check your motor--ESC plugs
              still soldered ( no heat damage ) ? ?
              Any incorrect connection causes resistance.
              any phase fire error can cause cogging and heating.
              W
              • Steven Vaccaro
                • 8723
                I agree to check all the plugs, resolder. I've received some esc's back with connectors that were cold soldered and caused faulty esc symptoms. Once I resolded the connectors, they ran fine.
                • Trevor January
                  • 30
                  well i played around with it today and found that i changed the timming to low and went to a harder start......and work better with no cogging , cause it would cog right from start up with out being run i can't see it being from heat cause it ran less then 98 on the esc and motor and it's fegerio 2382 with 40x52 3 blade with a 240 swordfish . and it only got hot once it started cogging , and i got some new heat shrink for the cause the other shunk when it got hot cogging.
                  i found that i need a prop for this set up better then grimracer or atleast bigger
