Will my 1527 handle a 645....?
  • Make-a-Wake
    FE Rules!
    • 5557
    Will my 1527 in my 45" Dumas(my avatar) handle a 645? Its a 1y 1250kv.................i'm running a 445 right now and it just gets warm.........i dont know, seems just a bit big, but i got a balanced and sharpened one for free...........
  • Rumdog
    • 6453
    Easily, very easily. You're not even loading it yet, which may be causing heat. I'd prop up to at least a x450. Kind of a big boat for a 1527 though.
    • Make-a-Wake
      FE Rules!
      • 5557
      Its 6s by the way, forgot that part. The motor seems big enough to me, its not real heavy for the length and rides fairly high. Thanks, it seemed a bit large so i was looking for opinions...............a 642 kept popping into my head..............
      • Rumdog
        • 6453
        WEre talking about a 1527. A ul-1 motor will spin a 45mm prop. I used the 1.5d on 5s2p with a x455 in a 34" cat. The motor will spin a big prop!
        • sailr
          • Nov 2007
          • 6927
          I run a 447/3 on my 1527 on 6S with no sweat. A 645 is a no brainer for that motor on 6S. In fact, try the 447/3. I have mine in an Aeromarine Sprintcat 40 and she hauls the mail!
          Mini Cat Racing USA
          www.minicatracingusa.com
          • Make-a-Wake
            FE Rules!
            • 5557
            Wow............the 1527 has some balls huh? It is a sport boat basically, looks real scale with the full interior, windshield and padded rear sundeck and at the 35mph that it goes it looks good. But, we all want a little more speed, im thinking the 645 will push it to low 40's.
            • Rumdog
              • 6453
              Yep, mine was in the same hull as sailr's, and ran a x455. Got me to mid sixties!
                An x645 is way too small for that hull, it will slip and be inefficient. The x447/3 makes more sense, but an x450 is not too big. The x450 has about the same pitch as the x645 but more blade area and a larger thrust cone for more efficiency - and thus more speed. Watch the heat but that prop should be easy for the motor. I run a pitched-up x455 with that motor in my SprintCat on 6S....
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  Wow.............a 645 too small............then im really underpropping it with the 445. I'll throw the 645 on it and see! Now a 548 is catching my attention............??
                  • Jeepers
                    • May 2007
                    • 1973
                    I run a x457 on a 1527 1.5d.
                    a 645 is a toy prop for that 1527 1y motor. guys at the Nationals were using a 455 on the same motor your using. and I believe it was mild for them.
                    • Make-a-Wake
                      FE Rules!
                      • 5557
                      Man, i really feel like a wimp now..............wonder what kinda speed those big props would give the boat..................50's?
