What can possibly go wrong with this set up???
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    Damn, must be my bad luck...
    I will give this a try one more time and if it wont work you guys will see my boat on swap shop....
    Canada
    • Doby
      KANADA RULES!
      • 7280
      Bring it along Saturday so we can check it out for whatever we might be able to see.
      Grand River Marine Modellers
      • LiPo Power
        • May 2009
        • 3186
        I will....
        Canada
        • BakedMopar
          No Mo Slipah
          • Sep 2009
          • 1679
          Couple questions.
          1. Is the prop modded in any way?
          2. How is the boat running? any hopping in corners etc.
          • LiPo Power
            • May 2009
            • 3186
            Prop is B&S, she was flying flawless....
            Here is video from last summer on the same set up:
            Originally posted by BakedMopar
            Couple questions.
            Canada
            • ray schrauwen
              • 9472
              Originally posted by TRUCKPULL
              Robert
              That is the same as my "P" Mono race setup - 447/3 prop
              It will average about 140 AMP's when trimmed right.
              If you want it to fail let Ray drive it.
              Larry
              Oh sure, nice dig buddy. I run that setup with a Turnigy 180 but, my 447x3 is modded like yours & Steve R's...
              What the Heck?
              • Rumdog
                • 6453
                So, what was the timing set at?
                • ray schrauwen
                  • 9472
                  It could have been allot of things, clogged cooling, bad solder joint.
                  Yeah, I've baked about $200 worth of Himodel/Mystery esc's in many boats, never worried about warranty.
                  I'm glad I'm anal about my electronics, otherwise I'd have smoked a lot more. Learned allot about ESC construction and thier limits etc...
                  If the Chinese would only listen to me, Castle would be toast! They have decent designs but, execution is poor, cooling is usually minimal on the Turnigy's & Aquastar's, almost always they could add more water cooled heat sinks in between fet layers etc... Better quality copper wire...
                  • ray schrauwen
                    • 9472
                    Factory default is Auto I believe...
                    • Rumdog
                      • 6453
                      so 15 degrees? If so, the Delta would run hot!
                      • LiPo Power
                        • May 2009
                        • 3186
                        If I can remember, timing was auto....
                        Could that be one of the possible reasons to burn up my set below 3 minutes???
                        What timing should I set in case I will get the same set up again?
                        Robert
                        Canada
                        • cybercrxt
                          • 2909
                          #27
                          I will be honest with you, I do not think that 240a HV Swordfish can run on 4 and 5s setups. I think the high kv demands of those setups reveal some issues with the 240 amperage ability of the controller, where the lower kv/ higher voltage setups mask its 240 amp ability since you are probably pulling 150amps or less with 6s or higher. The reason I say this, I had two of these esc's, one on 4s2p, and the other on 5s2p. The 4s2p setup ran around for 1 or so laps, and toasted, and that was on a 1515 1y castle, the 5s2p was with a 1518 1y castle and the controller got so hot, I discontinued using it. I put back in the controllers I was running before the changeover (a turnigy 180a and hydra 240a lv), and the boats went right back out, ran fine, no heat issues. These setups were on my tunnel hulls, which run WAY more efficiently than monos. I have heard of great success with this controller on the higher voltage/ lower amp draws tho, but this sounds like an issue that is rearing it ugly head. Also, Doug Smock recently explained D winds vs. Y winds, and D wings are hell on esc's.....
                          • ray schrauwen
                            • 9472
                            #28
                            Nicce post Mike, interesting !
                            • Rumdog
                              • 6453
                              #29
                              Mike, have you tried the newer version with the 8 awg wires? I had 2 of the originals. They both ran hot and went bad on 9s2p. I received a warranty with the new wiring and all was good. Bacl on topic, 15 degrees timing would have definately heated things up. Did it de-mag or what?
                              • johnf
                                • Dec 2009
                                • 1078
                                #30
                                MarkF brought up an interesting point in the FS thread. Did you check the length of the screws used to mount the motor?
                                Catching Air!
