balsa cat
  • ezhitz
    • Aug 2009
    • 428
    balsa cat
    I was wondering would the UL1 motor and esc work in a 30" balsa cat
    i built or would i be better off using something like a 9XL or 8Xl .
    :canada
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7128
    UL1 would probably be marginal and not enough torque, better off with one of XL cans you mentioned
    "Look good doin' it"
    See the fleet
    • dana
      Banned
      • Mar 2010
      • 3573
      i used a ul-1 motor and speed control in a 29' balsa cat i did...damn thing screwed. honestly it was hard to keep in the water at full throttle
      • jstolz
        • 335
        Try the UL-1 motor. I'll bet it works just fine.
        • DPeterson
          • 842
          Geez - That Jay guy wins a National event and now he knows everything.
          How are ya Jay? I am planning on a rematch next year!
          I would say if the Balsa Cat weighs 6 lbs or less that the UL1 is worth trying. If heavier and because Cats run a little wet in corners and such it may be iffy.
          Doug
          Doug Peterson
          IMPBA 19993
          www.badgerboaters.com
          • ezhitz
            • Aug 2009
            • 428
            Thanks guys for your input i took the boat into work today and put it on the scale as it sits
            with everything in it less motor and esc its under 3 lbs. (2.835) so i guess it wouldn't hurt to try the UL1 setup.
            :canada
