Esc q for you knowledgeable guy
  • Gerwin Brommer
    • Dec 2008
    • 918
    GM Genius 120 will work on 1s
    The BK esc's do.
    The old Turnigys Plush opto 100A do
    • Ub Hauled
      • Aug 2007
      • 3031
      first big hurdle would be getting the cutoff to be lower then the minimum of 4v... which i think from a user standpoint is impossible.
      thanks Gerwin...
      now I am on a search for a high amp (200+) 1s ESC... if anyone hears of one, please let me know...
      • RaceMechaniX
        • Sep 2007
        • 2821
        Jan,
        I am pretty sure with the Castle link you can disble the LVC as if you were using a NiMH pack.
        Otherwise, the 1S Castle Mamba Max Pro is the the only one I know of other then the ones listed above.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • Ub Hauled
          • Aug 2007
          • 3031
          I was using the custom V cutoff and it would not go lower then 4.0v
          I'll look a little better but there aren't many options there...
          worth a shot though...
          • Ub Hauled
            • Aug 2007
            • 3031
            I tried it again, and read what each setting was for... they say that the 4v cutoff is for Nixx of 6 or less, but it still does not work... will try one more thing...
            • Ub Hauled
              • Aug 2007
              • 3031
              Ok, so I fully charged the 1s pack and set the LVC to 4.0v (minimum), the Hydra 120 arms and works the motor... here's the catch, a fully charged LiPo cell is 4.2v and it has a bit of a discharge before you can actually plug it in, longer story made short, one will not have more then 0.2v
              to run before the LVC kicks in and spoils the fun. The Hydras do not allow, less then 2s for that particular reason...
              • RaceMechaniX
                • Sep 2007
                • 2821
                So you need the Mamba max Pro 1S I guess......
                Tyler Garrard
                • Ub Hauled
                  • Aug 2007
                  • 3031
                  #23
                  It sounds good Tyler, but I believe it is only rated to 100amps and I need about double+ of that...
                  damn SAW events, always make me buy the higher end stuff
                  • RaceMechaniX
                    • Sep 2007
                    • 2821
                    #24
                    What class uses a single cell?
                    Tyler Garrard
                    • D. Newland
                      • Dec 2007
                      • 1030
                      #25
                      I'm working on getting M-2 to allow it for SAW/2-Lap only. The voltage rule never got updated when we switched to LiPo. On purpose I suppose, but I'm working on correcting it.
                      • RaceMechaniX
                        • Sep 2007
                        • 2821
                        #26
                        Jan,
                        For M-2 you have to run a brushed motor, how do you figure you are going to pump more than 100 amps through a brushed motor?
                        Besides, many of the brushless controls can be run as a brushed set-up by connecting all three phases of the controller to the ground and then connecting the positive motor terminal to the battery directly. Similar to the brushed Novak controllers of days past.
                        Tyler
                        Tyler Garrard
                        • D. Newland
                          • Dec 2007
                          • 1030
                          #27
                          M-2 is any motor. Currently 4 NiMH cells. Future will be 1S Lipo.
                          • RaceMechaniX
                            • Sep 2007
                            • 2821
                            #28
                            My rulebook says the following:
                            "A single .05 motor with brushes, any endbell, ferrite magnets.
                            Power Limits: 1-4 Ni-chemistry cells are permitted."
                            Unless it was amended recently.
                            Tyler Garrard
                            • D. Newland
                              • Dec 2007
                              • 1030
                              #29
                              Woops. My bad. I was just looking at it today, too.
                              The proposal for M-2 will be any motor, 1S lipo voltage parameter.
                              • RaceMechaniX
                                • Sep 2007
                                • 2821
                                #30
                                To be frank, this seems a little backwards unless the entire set of rules are deifned for M-2.
                                I see there is no capacity limit or hull length restriction either.
                                I guess if Jan was crazy enough (OK check there) he could strap a 9000kv motor into a 34" hull with 1S4P and assuming he could find a 500a controller he could go ballastic?
                                Tyler
                                Tyler Garrard
