Boat Batt.
  • gartman
    • 31
    Boat Batt.
    Hi, I Have a 26" V hull with a Fiego 7c 3511 kv motor and a 120 amp esc what would be a good Lipo batt. to use gartman.paul@gmail.com
  • Diesel6401
    Memento Vivere
    • 4204
    Is it like a DF26 copy? Is THIS the motor your referring to?
    * With a 3511kv motor, on a 2s lipo you should have a nice sport boat. I would stick with 2s, and if you really feel the need for speed 3s (very cautious & prop wisely). I would make a nice sport boat out of it and run 2 2s packs in parallel for some extra run time. Prop wisely with those high kv motors. I would imagine something under 40mm. If using a 3/16 shaft something like a x438 maybe or even a x637 (maybe to much pitch though). Do a search of DF26's and read what others are running.
    - Diesel's Youtube
    - Diesel's Fleet
    • Diesel6401
      Memento Vivere
      • 4204
      The boat was used and I'm new at rc boats, I used a 3s 2200 mAh 25c burst 50c and the batt. swelled.
      Check out this chart. The motor you have can pull up to 88 max amps. The 25c battery you have can only supply 55 amps continous or 110 burst. I'd assume that motor will run more than 55 constant, which is why your packs swelled, they simply could not handle the amp draw.
      - Diesel's Youtube
      - Diesel's Fleet
      • gartman
        • 31
        The boat was used, an i used a 3s 2200 mah 25c burst 50c and it swelled. i think a 3s mah 2200 45c burst 90c ?
        • Diesel6401
          Memento Vivere
          • 4204
          You need more mah, something 4000+ or run those 2200mah in parallel for a total of 3s 4400mah. In my opionin those 2200 arent going to cut it by themselves.
          - Diesel's Youtube
          - Diesel's Fleet
          • gartman
            • 31
            Could you tell me what lipo batt. i should use? Thanks
            • gartman
              • 31
              If i use 4400mah what c should i use?
              • Diesel6401
                Memento Vivere
                • 4204
                You can use the batteries you have you just need to run 2 of the same batteries in the boat at the same time in a Parallel circuit. Do have have 2 of the EXACT same batteries?
                - Diesel's Youtube
                - Diesel's Fleet
                • gartman
                  • 31
                  one 3s 2200 25c and one 3s 2200 45c. can use both together?
                  • Diesel6401
                    Memento Vivere
                    • 4204
                    I personnally try to run 30c and up, just my preference. I do have some 25c's I run in my no step mono. I would stick to 25c and up never less than 20c.
                    If you don't understand how series and parallel circuits work you should really read up on it. It willl save you money by allowing you to muniplate different voltages and mah and configurtions. If you only want to run 1 battery at a time in your boat this may help http://www.hobbycity.com/hobbyking/s...dProduct=12936
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • gartman
                      • 31
                      Thank you for the help
