Beginner advises
  • nho1
    • Apr 2010
    • 25
    Beginner advises
    Hello,
    As a newbie and interested in buiding a electro boat, I would like some advises.
    The hull I looking at is a Octane 45 (lengh 1150mm, width 310mm, weight 3000g).
    Is it possible to run such mono hull with brushless motor without being very expensive?
    Advise of motor and ESC for such hull (would be greatful if you give link to motor/ESC at for example HobbyKing).
    Thanks in advance!
  • forescott
    Hopelessly Addicted to RC
    • 2686
    You will need one of these....http://www.offshoreelectrics.com/pro...runner&cat=135
    • forescott
      • 2686
      And one of these.....http://www.offshoreelectrics.com/pro...ra180-highvolt
      • forescott
        • 2686
        And four of these...http://www.hobbyking.com/hobbyking/s..._30C_Lipo_Pack
        • forescott
          • 2686
          Plus a motor mount and coupler.
          • Doby
            KANADA RULES!
            • 7280
            Do not use a Hydra...apparently Littlescreamers do not play well with them....there is a thread on here somewhere.....Mine died on its first run with that motor....then I found that thread.
            Grand River Marine Modellers
            • forescott
              • 2686
              Thanks for the info Doby! What esc did you end up with? I might be starting a large scale build with the little screamers motor and I would like to know. Thanks!!
              • Doby
                KANADA RULES!
                • 7280
                Nothing right now, still pissed that it took out the Hydra,,,,its in indefinite drydock.
                I heard that the Turnigy Monster 200 works.
                • nho1
                  • Apr 2010
                  • 25
                  Thanks for the advises!
                  I would really appriciate if you could give advises of the items I need to purchase (motor mount?, coupler?, drive shaft? etc etc). I am a real newbie and want to understand want amount we are talking about.
                  Any idea if the hull I suggested is suitable?
                  Or any other suggestions of how to build a boat of minimum 1000mm length? Set-up?
                  Thanks for all your help.
                  • nho1
                    • Apr 2010
                    • 25
                    Is this ESC http://www.hobbywing.com/english/Art...?ArticleID=452, suitable for the above motor?
                    • JMSCARD
                      • Mar 2010
                      • 3444
                      that esc is only suitable up to 6s... not enough voltage... at a absolute minimum you will want to run 8s... I am going to run my little screamers in my DF Sniper (45" mono) on 12s with a turnigy monster upfitted with liquid cooling.... Here it is mounted...just need to get it wet!
                      • nho1
                        • Apr 2010
                        • 25
                        How do you run on 12S? Is that like two 6S i serial? I can not find any 12S Lipo's.
                        Were can I find turnigy monster? Price?
                        Suggestion were to buy?
                        • JMSCARD
                          • Mar 2010
                          • 3444
                          Yes 12s is two 6s in serial....
                          http://www.offshoreelectrics.com/wiring.php
                          But I am actually gonna run a quantitiy of 4, 6s 5050mah packs.... two in parallel and then into serial to make 12s2p 10100 mah... for longer run times of course....
                          anyhow the turnigy monster can be bought here:
                          http://www.hobbyking.com/hobbyking/s..._Brushless_ESC
                          And I would put a couple computer fans atop the esc and run with a small lipo... or I have mine upfitted with brass tubing..... they are supposed to work great with the screamer motor...
                          • nho1
                            • Apr 2010
                            • 25
                            Do you have any pictures of your boat?
                            Were can I learn more of the type of equipment I need?
                            I assume I need motor mount, some drive shaft etc... I really would like to build a large scale electric boat, however I need much input.
                            • nho1
                              • Apr 2010
                              • 25
                              Another question, does it work good to order from HobbyKing?
                              I live in Sweden in Europe, wonder if I will have to pay for custom and duty?
