Six New NAMBA 2-Lap records set today
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /Mono -
Tony or Mark, was the LVC setup with the auto calculate or was it setup for four cells? My Turnigy 180 in auto calculate mode seems to do this every now and then. I hasn't done it when set up to manual four cell. Glad it's all figured out.If all of your wishes are granted, many of your dreams will be destroyed!Comment
We disabled the LVC with the programming box and full throttle was restored. This is the Seaking labeled SC, not the Turnigy labeled one if there's a difference. Anyway, problem seems solved.
It seems the Sea King & Turnigy are so similar that they can have the same inherent programming problem. Or maybe the programming card selects the next higher cell count setting to the one that is entered.
Eg: If the cutouts are programmed at say 3.3V & a cell count of 4s is entered, the programming card/ESC may be entering 5s.
This would give a cutout voltage of 16.5V.
With a fully charged 4s pack at 16.8V, as soon as you hit the throttle the voltage drop would trigger the LVC.
I don't have one to play with so it's only a theory.
But it sounds similar to the problem that Castle had a while ago with the wrong timing settings being programmed to the ones being selected.
I guess by setting the LVC manually with the TX, you could tell if it's the card or the ESC
Like I said, just a theory.
Paul.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Ahhh well. I guess it's a general failing of the LVC programming within the ESC then, if it was working before. So bang goes my theory.
Now that you mention it, I think the one at our club was working previous to the problem. It was a while ago.
I'm sorry for you that it happened at such a critical time Mark.
All the best.
Yeah. All the S and T records set with the ConquestTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WRComment
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
some vids
Brian's P(spec) OPC running 31 sec. in P-OPC
Tyler's Aero Conquest on 10S [ T-Offshore]
Tyler's Cat on 8S [S-Offshore]
A sorely missing vid was Brian's P-Hydro which was lightin' it up !
Had camera problems, sorry [I'd call it human error but I failed the physical]
Last edited by properchopper; 08-05-2010, 11:21 PM.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Here are the official results with a little editing on the details. I did take some videos and even have several of Brian with both his P and N2 hydro's, but its going to take some time to get them off the video camera and onto youtube.
Tony, Thanks for the videos of mine.
Jan, Next time bring a boat.
Mark, bummer on the esc.
Record Type: 2 LAP
Class: S OFFSHORE
Date: 7/31/2010
Seconds: 25.609
MPH: 46.85
Engine/Motor: NEU 2215
Hull: AEROMARINE
Prop: OCTURA X460
Speed Control: SCHULZE
Battery: FP 8S2P
Record Type: 2 LAP
Class: N-2 MONO
Date: 7/31/2010
Seconds: 28.452
MPH: 42.17
Engine/Motor: NEU 1515
Hull: DELTA FORCE 26
Prop: OCTURA M645
Speed Control: CASTLE 240LV
Battery: FP 2S2P 30C
Record Type: 2 LAP
Class: N-2 OFFSHORE
Date: 7/31/2010
Seconds: 27.310
MPH: 43.93
Prop: OCTURA M645
Speed Control: CASTLE 240 LV
Record Type: 2 LAP
Class: Q MONO
Date: 8/01/2010
Seconds: 29.37
MPH: 40.85
Engine/Motor: NEV 1521
Hull: DELTA FORCE 33
Prop: OCTURA M642
Speed Control: TURNIGY 180
Battery: FP 6S1P 30C
Record Type: 2 LAP
Class: Q OFFSHORE
Date: 8/01/2010
Seconds: 30.97
MPH: 38.74
Prop: OCTURA M642
Record Type: 2 LAP
Class: T OFFSHORE
Date: 7/31/2010
Seconds: 23.001
MPH: 52.17
Engine/Motor: NEV 2215
Hull: AEROMARINE CONQUEST
Prop: OCTURA X457
Battery: FP 10S 25C
Record Type: 2 LAP
Class: S HYDRO
Date: 7/31/2010
Seconds: 25.695
MPH: 46.70
Prop: OCTURA X462
Battery: FP 8S2P 30C
Record Type: 2 LAP
Class: GX-1 DEEP VEE
Date: 7/31/2010
Seconds: 31.005
MPH: 38.70
Engine/Motor: ZENOAH
Hull: AQUACRAFT
Prop: ABC 2716
Record Type: 2 LAP
Class: G-1 DEEP VEE
Date: 7/31/2010
Seconds: 32.02
MPH: 37.47
Hull: AQUACRAFT
Prop: ABC 2716
Record Type: 2 LAP
Class: G-2 HYDRO
Date: 8/01/2010
Seconds: 21.805
MPH: 55.037
Engine/Motor: CC RACING
Hull: GRIM REAPER
Prop: ABC 2916
Record Type: 2 LAP
Class: GX-2 HYDRO
Date: 8/01/2010
Seconds: 20.916
MPH: 57.37
Engine/Motor: CC RACING BEAST
Hull: GRIM REAPER
Prop: ABC 2918
Record Type: 2 LAP
Class: C HYDRO
Date: 8/01/2010
Seconds: 17.05
MPH: 70.381
Engine/Motor: CMB/GRIM
Hull: GRIM REAPER
Prop: OCTURA/GRIM
Record Type: 2 LAP
Class: GX-2 SPORT HYDRO
Name: NICK HORMIGOSO
Date: 8/01/2010
Seconds: 22.362
MPH: 53.66
Hull: WHIPPET
Prop: ABC
Record Type: 2 LAP
Class: 1/10TH SCALE
Date: 7/31/2010
Seconds: 30.083
MPH: 39.88
Engine/Motor: HIMAX
Hull: SQUIRE SHOP
Prop: PROP SHOP 4518
Speed Control: CASTLE CREATIONS
Battery: HYPERION 5000
Record Type: 2 LAP
Class: P HYDRO
Date:08/01/2010
Seconds: 19.622
MPH: 61.16
Engine/Motor: NEV
Hull: RAPTOR MARINE
Prop: ABC 1718
Battery: FLIGHT POWER 5KLast edited by RaceMechaniX; 08-06-2010, 02:32 AM.Tyler Garrard
I'm new to the whole racing thing (don't race or have a place to race) but how long is the course and is the speed an average of the whole run?If all of your wishes are granted, many of your dreams will be destroyed!Comment
