Best set-up for a Pursuit Mono
This Hull runs like a wet dreamAt first with the X445 plastic it ran warm-hot Motor only everything else was cold including ESC & batts, this is with an outrunner as mentioned above so only a water cooled mount.
Next I went to the 40/53 prop & everything ran even colder & motor was just warm, this was with a good 6-7 minute run.
Speed wise pretty good considering it is only a 1800kv 35mm motor...I love 6 pole motors. I did not run a GPS (don't have one) but I would say it was running early-mid 40's at a guess.
I did not have to adjust trim tabs, stinger etc, the only thing that I did different from stock is make up some ply for each of the 2s packs which sit either side of the factory battery tray & around 60-70mm back. The 180a ESC sits right at the back of the factory battery tray, CG is at 250mm from the stern. It was quite windy today & the boat handled very well & turns like it's on rails.Comment
a guy in our club runs a pursuit in our offshore class on a SV27 motor 4s1p 5000 Turnigy lipos and a 445 for 4 minutes runs good!Comment
So far this is what I got so far:
- Leopard 4074 2200kv (although I just pick up a CC 1518 1800kv)
- Spektrum mr200
- JR servo
- Turnigy/Seaking 180
- M445
- .187 3/16 flexcable with octura 5mm - .187 couplerLast edited by Diesel6401; 09-29-2010, 07:24 PM.Comment
Id of thought the Leopard 2200 kv is to much for 6s but ideal for 4s where as the 1800kv was better suited to 5s possibly pushing to 6s for shorter runs.Comment
Im not running 6s on a leopard 2200kv, WAY to much kv. I will be running 2 4s lipos in parallel. If I do switch to the 1518 it would also be 4s or maybe even 5s for some fun.Comment
I have the leopard in mine (2200kv) with the 180amp esc spinning a X442 on 4s. The boat is ballistic & seems to always draw a crowed when i run it.
The older setup i was running was good for general running....now I have to keep my wits about me when I drive it, a lot of fun.Comment
So it seems like the a lot of people are running the leopard 2200 in their df33 copy or pursuits, I'm really thinking of changing over to the cc1518 I just got. I'm confused on what I should do. I haven't even stuck the boat in the water yet and maybe on a second motor change lol.Comment
Diesel - since it's ready to go now, get it wet! You're more than likely gonna see what the 1518 does in it eventually, so you have to run 'em both anyway. My guess is the 2200kv is gonna run well.Comment
