Why not cut that prop down a bit?
Large prop low pitch or small high pitch?
I like to find a prop that has sufficient thrust cone for the application and ride characteristics close to what I want then pitch up and modify for more/less lift and more rpm. I usually keep pitching up till I go past the point of good sense and then make another just back a bit.Comment
resurrecting this old thread with a question .
the op says What is the difference between running say a large prop (1.4 pitch) versus a smaller prop (1.6 pitch)
i thought 1.6 was a larger pitch prop? he mentions 1.4 being larger and 1.6 being the smaller prop .have i had this wrong all this time ?
another question if i may .i am running a 1600kv leopard motor in my pursuit with a x645 prop .best i can get is 55mph .someone said i should run a x447 because they get 63mph with the same setup running that prop .but the 447 has less total pitch how can it go faster?volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue riggingComment
another question if i may .i am running a 1600kv leopard motor in my pursuit with a x645 prop .best i can get is 55mph .someone said i should run a x447 because they get 63mph with the same setup running that prop .but the 447 has less total pitch how can it go faster?Vac-U-Tug Jr (13mph)Comment
The 645 may be too much of a load for the motor (didn't mention the can size which can determine how much torque the motor has) limiting the RPM's its actually putting out. Despite the 447 being a smaller total pitch prop on paper, it may allow your motor to run in its sweet spot, with more RPM's, i.e. more speed.
thats what the other guy said too.
4082 can ........hey ryan ,do you have a x447 to sell?Last edited by boatsrnew2me; 07-28-2018, 03:19 PM.volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue riggingComment
the 447 is bigger diameter but less total pitch then the 645 .
645=1.77x1.6=2.832
447=1.85x1.4=2.590...............less total pitchvolantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue riggingComment
hey ryan ,do you have a x447 to sell?Vac-U-Tug Jr (13mph)Comment
