Large prop low pitch or small high pitch?
  • egneg
    • 4670
    Why not cut that prop down a bit?
    IMPBA 20481S D-12
    • andym
      More Go Than Show Prop Co
      • 2406
      I like to find a prop that has sufficient thrust cone for the application and ride characteristics close to what I want then pitch up and modify for more/less lift and more rpm. I usually keep pitching up till I go past the point of good sense and then make another just back a bit.
      • boatsrnew2me
        • Oct 2016
        • 476
        resurrecting this old thread with a question .
        the op says What is the difference between running say a large prop (1.4 pitch) versus a smaller prop (1.6 pitch)
        i thought 1.6 was a larger pitch prop? he mentions 1.4 being larger and 1.6 being the smaller prop .have i had this wrong all this time ?
        another question if i may .i am running a 1600kv leopard motor in my pursuit with a x645 prop .best i can get is 55mph .someone said i should run a x447 because they get 63mph with the same setup running that prop .but the 447 has less total pitch how can it go faster?
        volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue rigging
        • fweasel
          master of some
          • Jul 2016
          • 4286
          He was comparing a larger diameter prop with a 1.4 pitch ratio to a smaller diameter prop with a pitch ratio of 1.6. You are correct in your understanding, the larger the pitch ratio, the more total pitch, for any given diameter.
          The 645 may be too much of a load for the motor (didn't mention the can size which can determine how much torque the motor has) limiting the RPM's its actually putting out. Despite the 447 being a smaller total pitch prop on paper, it may allow your motor to run in its sweet spot, with more RPM's, i.e. more speed. Swapping props and measuring the results is probably my favorite part of this hobby.
          Vac-U-Tug Jr (13mph)
          • boatsrnew2me
            • Oct 2016
            • 476
            thats what the other guy said too.
            4082 can ........hey ryan ,do you have a x447 to sell?
            • Speed3
              • Mar 2017
              • 371
              The bigger diameter will be faster having same total pitch as the smaller diameter prop of higher pitch ratio.
              The bigger diameter is faster because of higher prop efficiency.
              But the bigger diameter will also pull more amps.
              • boatsrnew2me
                • Oct 2016
                • 476
                the 447 is bigger diameter but less total pitch then the 645 .
                645=1.77x1.6=2.832
                447=1.85x1.4=2.590...............less total pitch
                • fweasel
                  master of some
                  • Jul 2016
                  • 4286
                  #23
                  I don't have any spare Octuras at the moment, but OSE has S&B 447's in stock
