Hobbycity/Joysway "Sea Fire" Hydro
  • paultbg
    • Mar 2012
    • 103
    #46
    An usefull advice
    Hello i am new here (and glad to meet you all) and somehow new to this hobby.
    I will receive soon (i hope) my Sea Fire boat.HK recommend 2 x 4400mah 2S 30C+ Lipo.
    My questions is: I have 2*2200mah 3s 25c lipo.Can I use them too?
    If so, do I need to take some extra caution?
    many thanks upfront
    Paul
    • sailr
      • Nov 2007
      • 6927
      #47
      NO! combining the 3 cell batteries in series will equal 6S. You will burn up the esc and motor!
      Mini Cat Racing USA
      www.minicatracingusa.com
      • paultbg
        • Mar 2012
        • 103
        #48
        No,I meant to use them alternatively, instead of the 2s ones.
        Obliviously in parallel, as the boat was designed.
        I know that parallel increase the amps and the series increase the voltage.
        The point is can I use 11.1v (3s) instead of 7,4v(s)?
        Many thanks
        Paul
        • TristanJones
          • Oct 2012
          • 266
          #49
          Can anyone please tell me where to get a replacement flex drive / drive shaft for one of these, motor slipped out of mount and damaged shaft.
          Mine has run 97.7km/h (60.70mph) on the GPS on 4s
          • Southwest
            • Sep 2012
            • 274
            #50
            Water is entering where strut and stuff tube met. Why; the strut is bigger and should be tapered to the same size the stuffing tube is. The strut is forcing water up the tube. You could use heat shrink over strut end and stuffing tube too!!
            • sailr
              • Nov 2007
              • 6927
              #51
              This is it and it also includes the coupler, drive dog, and prop shaft!
              http://www.hobbyking.com/hobbyking/s...Shaft_Set.html
              Mini Cat Racing USA
              • sailr
                • Nov 2007
                • 6927
                #52
                two packs in parallel will NOT give you higher voltage, only higher amperage. If you want higher voltage, you have to wire them in series!
                Mini Cat Racing USA
                • martin
                  • 2887
                  #53
                  Many thanks
                  Paul
                  The boat is designed to work with 2 x 2s in series giving 4s in total, on 1 x 3s it will be much slower.
                  • sailr
                    • Nov 2007
                    • 6927
                    #54
                    and 2 3S in series will burn up the ESC and motor.
                    Mini Cat Racing USA
                    • TristanJones
                      • Oct 2012
                      • 266
                      #55
                      thanks a million, no idea how I missed that. LOL
