5700kv in a mean machine
  • minikitty
    • May 2010
    • 27
    http://hobbyking.com/hobbyking/store...idProduct=6667
    How well will this motor work in a mean machine cat
  • Rumdog
    • 6453
    The mean machine is a 4s boat. The kv of that motor is WAY too high. Look for an XL size motor from around 1800-2200kv and you'll want at least a 150 amp esc. The motor you linked to would draw seriously big amp #'s with any kind of decent prop, and that's on 2s.
    • forescott
      Hopelessly Addicted to RC
      • 2686
      I'd like to see the castle 2200 on 4s in that hull. I agree with Rum, dont do it!!
      • Make-a-Wake
        FE Rules!
        • 5554
        It wont............
        • minikitty
          • May 2010
          • 27
          will it make it go too fast? I had a castle creations 5700 kv in my traxxas blast.
          • blackcat26
            High Speed Junkie
            • Sep 2009
            • 1598
            Porbably not but it will be smokey!
            • forescott
              • 2686
              Hmmmm...
              • Make-a-Wake
                FE Rules!
                • 5554
                It wont make it go too fast, it will barely go at all as it will not be able to rev up.
                Here are your answers so far, its obviously your decision.
                It wont
                it will be smokey!
                Hmmmm...HOT!!
                • Boatman
                  • Jan 2008
                  • 796
                  No as stated above and the reason being with these motors you want to shoot for an ideal of 30,000 rpm but with reasonable mass to the motor to spin the correct prop. I would imagine the MM hull would run great with a 45mm prop so obviously that motor wont turn that prop on a hull of that size. 4S LiPo @ 14.8V multiplied by kv of 2000 is just about perfect. Also as stated a Feigao XL motor or a Neu Castle motor at that kv would be great. I hope that makes sense.
                  • Alexgar
                    • Aug 2009
                    • 3522
                    crash and burn over 2s
                    • Flying Scotsman
                      Fast Electric Adict!
                      • Jun 2007
                      • 5190
                      How many volts and what was your experience with that motor in that hull?
                      Douggie
